How to debug frequent hangs in lv_task_handler
I’m experiencing frequent hangs (indefinitely, unless task watchdog reboots the board) at unpredictable intervals (seconds to hours). This has not changed after upgrading LVGL from 8.3.0-dev to 8.4.0, and ESP32 boards from 2.x to 3.x.
Much more rarely, there are also proper crashes (Guru Meditation), also in lv code.
CYB (ESP32S3-4827S043R)
Arduino IDE 1.8.19
esp32 boards v3.1.3
8.4.0
Stability
  • Consolidated all LVGL code into the main loop() (stopped using lv_timers to prevent race conditions)
  • Changed element udpate frequency (200-1000ms delays for various components), calling lv_timer_handler() every iteration of loop with 5ms delay.
  • Increased LV_MEM_SIZE to 48U * 1024U, 96U * 1024U
  • Tried various disp_draw_buf sizes (recommended width * 10 results in slow redraw, currently “sizeof(lv_color_t) * screenWidth * screenHeight / 4” )
  • Printing out stats (these always look healthy right up to the hang):
Free Heap: 187752 b, up 2012 s
Stack High Water Mark: 4884 bytes
LVGL Free: 35212, Frag: 1%, Biggest Block: 35012
LVGL Objects: 3
I honestly don’t know which part of my code is relevant. The entirety is here: esp32-spa-controller/display at master · akomakom/esp32-spa-controller · GitHub (relevant are gfx.h and display.ino and a copy of the lv_conf.h is there too as lv_conf.h.example)
The board uses a parallel display and Arduino_ESP32RGBPanel
Main loop:
    updateUI();  // updates ui elements if enough time has elapsed since last update
    lv_timer_handler();
    // other stuff (ESPNOW handlers)
    delay(5);
Items updated (even if unchanged) at every iteration include:
  • label text via lv_label_set_text_fmt(), including %f
  • hidden flags (LV_OBJ_FLAG_HIDDEN)
  • lv_obj_set_style_border_color
Crashes are rare, but Task Watchdog timeouts happen regularly, from a few seconds after boot to an hour after boot.
Stacktraces during WDT timeout vary a lot, but they are almost always in lv_task_handler() call and usually are in memory functions.
Examples:
Decoding stack results
0x4201db4f: lv_mem_buf_get at /home/akom/Arduino/libraries/lvgl/src/misc/lv_mem.c line 310
0x4200e217: lv_draw_mask_radius_init at /home/akom/Arduino/libraries/lvgl/src/draw/lv_draw_mask.c line 1385
0x42012426: draw_bg at /home/akom/Arduino/libraries/lvgl/src/draw/sw/lv_draw_sw_rect.c line 151
0x42013765: lv_draw_sw_rect at /home/akom/Arduino/libraries/lvgl/src/draw/sw/lv_draw_sw_rect.c line 73
0x420bfeb1: lv_draw_rect at /home/akom/Arduino/libraries/lvgl/src/draw/lv_draw_rect.c line 66
0x4200658c: lv_obj_draw at /home/akom/Arduino/libraries/lvgl/src/core/lv_obj.c line 561
0x42006d03: lv_obj_event at /home/akom/Arduino/libraries/lvgl/src/core/lv_obj.c line 873
0x420bf851: lv_obj_event_base at /home/akom/Arduino/libraries/lvgl/src/core/lv_event.c line 96
0x42004165: event_send_core at /home/akom/Arduino/libraries/lvgl/src/core/lv_event.c line 452
0x420042a5: lv_event_send at /home/akom/Arduino/libraries/lvgl/src/core/lv_event.c line 74
0x4200b4d9: lv_obj_redraw at /home/akom/Arduino/libraries/lvgl/src/core/lv_refr.c line 148
0x4200b5a3: refr_obj at /home/akom/Arduino/libraries/lvgl/src/core/lv_refr.c line 970
0x4200b531: lv_obj_redraw at /home/akom/Arduino/libraries/lvgl/src/core/lv_refr.c line 182
0x4200b8b3: refr_obj_and_children at /home/akom/Arduino/libraries/lvgl/src/core/lv_refr.c line 854
0x4200b9d9: refr_area_part at /home/akom/Arduino/libraries/lvgl/src/core/lv_refr.c line 789
0x4200c5ab: _lv_disp_refr_timer at /home/akom/Arduino/libraries/lvgl/src/core/lv_refr.c line 678
0x4201ef26: lv_timer_handler at /home/akom/Arduino/libraries/lvgl/src/misc/lv_timer.c line 313
0x42003aaf: loop() at /home/akom/workspace/personal/esp32-spa-controller/display/display.ino line 437
0x420303e0: loopTask(void*) at /home/akom/.arduino15/packages/esp32/hardware/esp32/3.1.3/cores/esp32/main.cpp line 74
0x4037fb62: vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c line 139
0x4201cf32: _lv_area_is_point_on at /home/akom/Arduino/libraries/lvgl/src/misc/lv_area.c line 243
0x4201d02b: _lv_area_is_point_on at /home/akom/Arduino/libraries/lvgl/src/misc/lv_area.c line 282
0x4201d0a7: _lv_area_is_in at /home/akom/Arduino/libraries/lvgl/src/misc/lv_area.c line 339
0x42006493: lv_obj_draw at /home/akom/Arduino/libraries/lvgl/src/core/lv_obj.c line 506
0x4200b459: lv_refr_get_top_obj at /home/akom/Arduino/libraries/lvgl/src/core/lv_refr.c line 817
0x4200b483: lv_refr_get_top_obj at /home/akom/Arduino/libraries/lvgl/src/core/lv_refr.c line 824
0x4200b951: refr_area_part at /home/akom/Arduino/libraries/lvgl/src/core/lv_refr.c line 730
These are not in lv_task_handler(), I just realized
0x4201f190: block_locate_free at /home/akom/Arduino/libraries/lvgl/src/misc/lv_tlsf.c line 774
0x4201f2a5: lv_tlsf_malloc at /home/akom/Arduino/libraries/lvgl/src/misc/lv_tlsf.c line 1101
0x4201da65: lv_mem_alloc at /home/akom/Arduino/libraries/lvgl/src/misc/lv_mem.c line 134
0x42024526: lv_label_set_text at /home/akom/Arduino/libraries/lvgl/src/widgets/lv_label.c line 134
0x42003a46: updateButtons(unsigned long) at /home/akom/workspace/personal/esp32-spa-controller/display/display.ino line 640
0x42003a58: updateUI(_lv_timer_t*) at /home/akom/workspace/personal/esp32-spa-controller/display/display.ino line 240
0x42003aca: loop() at /home/akom/workspace/personal/esp32-spa-controller/display/display.ino line 435
0x42030408: loopTask(void*) at /home/akom/.arduino15/packages/esp32/hardware/esp32/3.1.3/cores/esp32/main.cpp line 74
This one repeated twice in a row:
0x4201f2c5: lv_tlsf_free at /home/akom/Arduino/libraries/lvgl/src/misc/lv_tlsf.c line 1166
0x4201daa5: lv_mem_free at /home/akom/Arduino/libraries/lvgl/src/misc/lv_mem.c line 179
0x4202456d: lv_label_set_text_fmt at /home/akom/Arduino/libraries/lvgl/src/widgets/lv_label.c line 162
0x42002ae5: dataReceivedServerStatus(struct_status_server*) at /home/akom/workspace/personal/esp32-spa-controller/display/display.ino line 480
0x420023fd: ESPNowUtils::OnDataRecv(esp_now_recv_info const*, unsigned char const*, int) at /tmp/arduino_build_987117/sketch/ESPNowUtils.cpp line 87
Just before that last hang:
Free Heap: 151128 b, up 1201
LVGL Free: 35208, Frag: 1%, Biggest Block: 35012
LVGL Objects: 3
After posting this I just realized that I’m updating a label from the ESPNOW data received handler. I’ll fix that and circle back.
I think that was it, no issues for 3 hours and counting. Never noticed that I was updating GUI from the wrong thread until I looked at the stacktrace more closely.
Sorry for the noise, though I am still curious whether there is a better way to debug (I’m guessing not for race conditions like this one).
