I have an infrequent freeze in LVGL - asserting on updating a text label with “block already marked as free”.
The triggering code appears to be in my status bar update code (the status bar updates every 100ms, and I see this assert once a week maybe.) Looking for help on debugging this somehow.
NXP RT1052 with FreeRTOS
V8.3.3
Debug this assert that happens very rarely, so hard to reproduce:
tlsf_assert(!block_is_free(block) && "block already marked as free");
Ensured using MUTEX around lv_tick and lv_task handlers (separately) as that is the only hint I’ve seen about this assert thus far.
Code
void lv_ticker( void *pvParameters ) {
TickType_t ticks = 10 / portTICK_PERIOD_MS;
UI_SemaphoreInit();
lv_interface_init();
vTaskDelay(ticks);
if (xTaskCreate(lv_redraw, "LV Redraw Task", 1024, NULL, 3, &lv_redraw_handle) != pdPASS){
assert(0);
for( ;; ){
vTaskDelay(ticks);
UI_TakeMutex();
lv_tick_inc(millisec); /*Tell LittelvGL that 10 milliseconds were elapsed*/
UI_GiveMutex();
void lv_redraw( void *pvParameters ) {
//It will redraw the screen if required, handle input devices etc
uint32_t millisec = 50;
static uint8_t _100ms = 0;
TickType_t ticks = millisec / portTICK_PERIOD_MS;
for( ;; ){
vTaskDelay(ticks);
UI_TakeMutex();
lv_task_handler();
if (_100ms++ >= 5){
_100ms = 0;
status_refresh();
UI_GiveMutex();
The assert is being triggered from the status_refresh
above, which goes to call the below (as noted, this is called millions of times without a problem, and then eventually somehow it asserts:
lv_label_set_text(screen->status_bar.bluetooth_label.obj, "");
