How to create fonts v8.4
I’m struggling to create a single font symbol using the font awesome instructions. I’m sure I’ve done this in the past and it worked fine but there must be something wrong/missing in the instructions.
ESP32-S3 with Arduino
8.4
Show a symbol instead of a square box
Following the guide here:
extern lv_font_t Icon_Bed;
or
LV_FONT_DECLARE(Icon_Bed);
//Bed Filled Icon (Classic Solid) — Free SVG Download | Font Awesome
#define FA_ICON_BED “\xEF\x88\xB6” //based off the conversion of f236
    //Create background button for light on off icon
    lv_obj_t * btn_bed_light = lv_btn_create(ui_Home_Screen);
    lv_obj_align(btn_bed_light, LV_ALIGN_TOP_RIGHT, -40, 0);
    lv_obj_set_height(btn_bed_light, 70);
    lv_obj_set_width(btn_bed_light, 80);
    lv_obj_set_style_bg_opa(btn_bed_light, LV_OPA_TRANSP, LV_PART_MAIN);
    //Create light switch indicator icon
    lbl_bedLight_Icon = lv_label_create(ui_Home_Screen);
    lv_obj_set_style_text_color(lbl_bedLight_Icon, lv_color_hex(LV_COLOUR_LIGHT_OFF), LV_PART_MAIN);
    lv_label_set_text(lbl_bedLight_Icon, FA_ICON_BED);
    lv_obj_set_style_text_font(lbl_bedLight_Icon, &Icon_Bed, LV_PART_MAIN| LV_STATE_DEFAULT);
    lv_obj_align_to(lbl_bedLight_Icon, btn_bed_light, LV_ALIGN_TOP_LEFT, -5, -5);
Just a rectangle in the top right.
Icon c file:
Icon_Bed.c (12.7 KB)
Screenshot of conversion settings:
URL of font converter:
Any help would be really appreciated!
you should use 0xf236 in Range field instead of Symbols. In symbols field you need to list symbols needs to include in font-file, for example - AaBbCc … etc
Oh my! What a school boy error.
I read through that multiple times and completely missed I needed to put the symbol in the range field not the symbols field. Kinda counter intuitive but hey, this is where we are.
Thanks for the help, it worked perfectly!
How did you get custom fonts to work on Arduino for the ESP32-S3. i’m using the S3 LCD 7 Inch that uses LVGL v8.4 and cannot figure out how to put custom fonts in my code, i downloaded from google fonts, then converted through LVGL Converter into a .C file, C file moved into the project folder. turned 0s into 1s in lv_conf. Duplicated .C file as .H file, so now there is a .C and .H file in the project folder. #include “font.h” and still it pops up with an error message saying
Compilation error: ‘lv_font_t’ {aka ‘const struct _lv_font_t’} has no member named ‘static_bitmap’
font size is 72
