I want to create all buttons of a button matrix from strings I read from a file.
ESP32 with ESP-IDF
8.3
I like to change my button text at run time.
What have you tried so far? and code to reproduce
static const char * btnm_map[] = {“Button 1”,“Button 2”, “Button 3”,""};
lv_btnmatrix_set_map(object, btnm_map);
I like to use
You will need to create the data structures dynamically and make sure they stay in memory until the btn_matrix is destroyed (e.g. using lv_mem_alloc or malloc). The map_data is an array of pointers to \0 terminated character strings.
I used something similar to this to create a btn_map from JSON:
// Create new btnmatrix button map from file
const char** my_map_create(const char* filename)
size_t arr_size = sizeof(char*) * (item_count + 1); // e.g. 3 buttons + blank item = 4
const char** map_data_arr = (const char**)lv_mem_alloc(arr_size); // memory size for the pointer array
if(map_data_arr == NULL) {
return NULL;
// find the total length of all the labels, including \0 termination bytes
size_t buffer_size = 0;
buffer_size += strlen("Button 1") + 1; // include the \0 byte
buffer_size += strlen("Button 2") + 1;
buffer_size += 1; // \0 for blank item
char* buffer = (char*)lv_mem_alloc(buffer_size); // memory size for all the strings
if(buffer_addr == NULL) {
lv_mem_free(map_data_arr);
return NULL;
memset(buffer, 0, buffer_size); // Important, last index needs to be 0 => empty string ""
// Fill buffer
size_t index = 0;
size_t pos = 0;
for(items) {
// read label here...
size_t len = strlen(label) + 1; // include the \0 byte
memccpy(buffer + pos, label, 0, len); // Copy the label text into the buffer
map_data_arr[index++] = buffer + pos; // save pointer to the label in the array
pos += len;
map_data_arr[index] = buffer + pos; // save an extra pointer to the terminating \0 byte
return map_data_arr;
