How to create a pie chart in LVGL?
I would like to create a pie chart where the circle is filled rather than using an arc.
LVGL simulator on VScode.
LVGL v8.0.0
I would like to create a pie chart similar to this:https://d2mvzyuse3lwjc.cloudfront.net/doc/en/UserGuide/images/2D_B_and_W_Pie_Chart/2D_B_W_Pie_Chart_1.png?v=83139
I would also like to know if it is possible to use a different colour for each portion of the pie instead of using only one colour.
I have created an arc with reference to the documentation (link:Arc (lv_arc) — LVGL documentation) but it does not produce the result I am looking for.
Since you are using v8 you can check out the meter widget.
It has a pie chart example in the documentation.
I haven’t used this myself, but it looks very close to what you want to achieve.
Oh, so there is a pie chart example. This will work fine. Thank you for your help!
