Hello everyone, I want to ask why we can’t add straight line scale, for example, let us choose the circle, or the straight line scale, because now we really want the straight line scale, but only through painting.And the calculation is only plastic, because the calculation is floating point, the larger the value, the greater the deviation. Is there a way, can you use floating point painting? Thank you.
I don’t completely understand your question due to the translation limitations, but you can use fixed point with a slider if you need decimal calculations.
我也不是很懂你到底想要什么功能呢
I want to make a circular scale into a linear scale. Is there a way? Thank you
I want the circular scale to support the linear scale,
进度条小部件不能满足你的需求吗
There is no feature in LVGL to draw a linear scale at the moment.
