How to create a img at the top of messagebox
  • I want to put a picture at the top of the message box,but the picture is on the mottom side
  • I usedlv_obj_set_size() to set the messagebox size,but the Height setting failed,it only drived by text lines
V7.10.0
        /* Create the message box as a child of the modal background */
        msgbox = lv_msgbox_create(obj, NULL);
        lv_obj_set_event_cb(msgbox, mbox_event_cb);
        lv_msgbox_add_btns(msgbox, btns2);
        lv_msgbox_set_text(msgbox, "\n\n\nHello world!");
        lv_obj_t* img_icon = lv_img_create(msgbox, NULL);
        //lv_obj_set_size(img_icon, 80, 140);
        lv_img_set_src(img_icon, &icon_heart);
        lv_obj_set_pos(img_icon, 0, 0);
        //lv_obj_align(img_icon, mbox, LV_ALIGN_IN_TOP_MID, 0, 0);
        lv_obj_align(msgbox, NULL, LV_ALIGN_CENTER, 0, 0);
Try running lv_obj_move_background(img); by default the image is appended to the end of the message box and it gets positioned by the message box automatically.
After using this function, it was be fine.
Cool background effect! Is the styling at the very top another image?
Yes, I used a background image on the message box, that provided by our graphic designer.
img_msgbox_bg
Hi,there are some new problems in V7.11,when i create a img on the top of msg_box,i want use lv_obj_align(imge, msgbox, LV_ALIGN_IN_TOP_MID, 0, 40) , to set the img’s position,but it dosen’t work.
another one is i called lv_obj_set_size(msgbox,x,y) to set the msg_box’s size,it dosen’t work too.i found the height is drived by text lenth only.
Hi @juneofive
I might be able to help with the last thing you mentioned. I ran into the same “problem” and I believe these lines of code “fixes” it so you can modify height and width by yourself.
 lv_cont_set_fit2                    (MsgBox, LV_FIT_NONE, LV_FIT_NONE);        //Modify the preset layout options and fits
 lv_cont_set_layout                  (Msg, LV_LAYOUT_OFF);
I haven’t tested them independently, but I hope it still works :slight_smile:
That might also solve your first problem
thanks very much,i copy your code after create msg_box, that it could set size,but all items’ postion of the msg box is on the top left. lv_obj_align(btnmx, NULL, LV_ALIGN_IN_BOTTOM_MID, 0, -10);could set postion,but i can’t find how to ge the label ,so it was still on top left
Yeah thats probably because the layout is working like “normal”, so i believe you just have to align the objects with lv_obj_align() and you should have complete control.
i use this to get the label’s obj:
        lv_msgbox_ext_t * ext = lv_obj_get_ext_attr(mbox);
		lv_obj_align(ext->text, NULL, LV_ALIGN_CENTER, 0, 0);
now it’s working well,Thank you again!
