How to create a Chinese Input Method?
how to create Chinese Input Method?
You would have to customize the keyboard character map.
emm…is there some example code? I think coutomize the keyboard character map may not work. Because when you want to input one Chinese Character, you will input several letters then spell one Chinese Character.Like which I showed below. I should input “zhong” 5 letters then it find out Chinese Character “中”
kb
I see. To do that, you would have to process the text area manually after each keypress. I don’t think we have any built-in functionality for this.
LV_EVENT_INSERT might help to manipulate the input.
Hi, now we have ime_pinyin can meet your needs and is still trying to add more functions.
你好,现在已经有了 ime_pinyin 组件,你可以直接在lvgl库(V8.3 +)中使用,我们正在努力尝试添加更多的功能。
请问lv_micropython如何set_dict,尝试了很多数据结构,不是报:AttributeError: ‘lv_pinyin_dict_t’ object has no attribute ‘py’ 就是报:SyntaxError: Cannot set field py on struct lv_pinyin_dict_t!
能给你一个lv_micropython的set_dict的例子么?
