I am trying to display images using the SJPG format, but I can’t get to display them correctly, I know I am doing something because I have a glitched image shown on my screen.
I know how to display images from .c files, but I would like to use files from system so I won’t need to recompile my code. I already tried to use the PNG decoder, but I couldn’t at all make it work or do something. Since my code runs on an embedded system, I figure out that using SJPG might be a better option.
The board is the Colibri iMX7 512MB and I am compiling it with GCC and Make. Our system is based on a Yocto Linux image.
v8.2.0
I want to display SJPG on my screen from system files without recompiling my code
I did enable in lv_conf.h the use of SJPG decoder library #define LV_USE_SJPG 1 and since I couldn’t figure out how to create my own driver (too complicated for me) I did try to use both STDIO #define LV_USE_FS_STDIO 0 and POSIX #define LV_USE_FS_POSIX 1, but none of them gave different results, both gave me a glitched image.
I did set the correct PATH to my SJPG file "/home/FTC/images/" and set a cache size of (4U * 64U * 1024U) (we have lots of memory).
/*API for fopen, fread, etc*/
#define LV_USE_FS_STDIO 1
#if LV_USE_FS_STDIO
#define LV_FS_STDIO_LETTER 'Z' /*Set an upper cased letter on which the drive will accessible (e.g. 'A')*/
#define LV_FS_STDIO_PATH "/home/FTC/images/" /*Set the working directory. File/directory paths will be appended to it.*/
#define LV_FS_STDIO_CACHE_SIZE (4U * 64U * 1024U) /*>0 to cache this number of bytes in lv_fs_read()*/
/*API for open, read, etc*/
#if LV_USE_FS_POSIX
#define LV_FS_POSIX_LETTER 'A' /*Set an upper cased letter on which the drive will accessible (e.g. 'A')*/
#define LV_FS_POSIX_PATH "/home/FTC/images/" /*Set the working directory. File/directory paths will be appended to it.*/
#define LV_FS_POSIX_CACHE_SIZE (4U * 64U * 1024U) /*>0 to cache this number of bytes in lv_fs_read()*/
/* JPG + split JPG decoder library.
* Split JPG is a custom format optimized for embedded systems. */
void displayImage(void)
lv_split_jpeg_init();
lv_obj_t * img;
img = lv_img_create(lv_scr_act());
/* Assuming a File system is attached to letter 'A'
* E.g. set LV_USE_FS_STDIO 'A' in lv_conf.h */
lv_img_set_src(img, "A:teste.sjpg");
//lv_img_set_src(img, "Z:teste.sjpg"); // One or another
