How to control the calendar using LV_KEY_?
I want to manage the calendar by sending an event LV_EVENT_KEY
8.3
PanelEditParam.Calendar = lv_calendar_create(PanelEditParam.MainPanel);
PanelEditParam.Calendar_header = lv_calendar_header_dropdown_create(PanelEditParam.Calendar);
lv_obj_set_width(PanelEditParam.Calendar, 230);
lv_obj_set_height(PanelEditParam.Calendar, 240);
lv_obj_set_align(PanelEditParam.Calendar, LV_ALIGN_CENTER);
PanelEditParam.group = lv_group_create();
lv_group_add_obj(PanelEditParam.group, PanelEditParam.Calendar);
then i send the key code to the group
int key = LV_KEY_DOWN;
lv_group_send_data(PanelEditParam.group, &key);
key = LV_KEY_DOWN;
but the calendar does not change the selected day
Please help me solve this problem.
In general, can the calendar be controlled by the LV_EVENT_KEY event?
I can’t do anything
as you can see
c – a character (use LV_KEY_.. to navigate)
so you should use key code, not it pointer.
lv_group_send_data(PanelEditParam.group, key);
Yes, I fixed this error, but nothing changed.
