How to compile into firmware?
How would I compile this into the MicroPython firmware? I have made many changes to all the files of MicroPython so I am wondering if there is a simple way to compile It into the firmware. (for example maybe as a USER_C_MODULE?)
Have you tried this binding yet?
It’s a spinoff of the official binding. It is able to build using a single command. It takes care of the majority of the build requirements for you.
At the moment is works with the ESP32, Unix and macOS. I want to add other MCU’s like the STM32 but I do not know the hardware.
Thank you. I’ll try it.
Hi, did you try it? If so, do you know where the .bin file is generated?
I did try it and it worked perfectly. After compiling, it should say how to flash it but if not, the .bin should be “build/YOURBUILDNAME.bin”.
