How to check if obj is deleted
I would like to know if somebody has a good way of checking whether or not the object is deleted
I’m using the simulator
A pretty new one, but I don’t think anything has changed
I would like to know if there is an easy way to check if obj is deleted
I can’t really think of a good general way of doing it.
It’s impossible because C makes it impossible. Object references are just pointers to memory used to hold the object.
Suppose you were to create an object, delete it, and then make another object. The C allocator would notice the free memory and create the new object in that location. Thus, the same reference would be used for the new object.
The C approach is to keep track of when you delete the object and set all pointers referencing it to NULL. There is no better way of doing this in C that I know of - it’s a limitation of the language.
So I would have to do something like this:
//inside function or callback
if (obj == ObjToCheckFor) {
      ObjToCheckFor = NULL
}// and so on...
//and this outside the function when i want to check if its deleted or not, and run code depending on it
if (ObjToCheckFor != NULL) {
     //run whatever here
I think that would work.
