How to change the state of a button
How to change the state of a button.
ESP32, WT32-SC01, SquareLine Studio + PlatformIO + Arduino Framework
8.2.0
Change the state of a button.
Tried the following functions, but none of them are accepted:
  • lv_btn_set_state
  • lv_obj_set_state
Could not find anything which worked.
When you say set the state do you mean enable/disable it?
Regards
I think it is called CHECKED and RELEASED.
I can get the status using lv_obj_get_state.
But trying to change the state using lv_obj_set_state results in not declared in this scope.
What are you trying to achieve?
I have a button which can control a lamp through MQTT.
But this lamp can also be controlled by a different controller through MQTT.
So if the state of the lamp changes by a different controller, this should be reflected by the state of the button.
Can you share any code or screenshots?
It sounds like you need a switch instead of a button.
If I would use a switch, how do I change its state?
Have you read the docs?
https://docs.lvgl.io/latest/en/html/widgets/switch.html
I think function “lv_obj_add_state(obj*,state)” would work ,state can be any thing like LV_STATE_PRESSED
you can refer Link-Objects — LVGL documentation
This works!
I can set and reset the buttons state with lv_obj_add_state() and lv_obj_clear_state(), using LV_STATE_CHECKED.
Thanks!
