How to change the spacing between bars in a chart?
I created a columns chart with a single series and it works, except that the spacing between the bars is way too wide. Is there a way to increase the bars’ width and reduce the spacing width?
stm32f401
LVGL_VERSION_MAJOR 7
LVGL_VERSION_MINOR 5
LVGL_VERSION_PATCH 0
LVGL_VERSION_INFO “dev”
Wider bars and less space between them.
Searched the documentation, API, and the forums here.
It’s a general questions about the capabilities of the LVGL COLUMNS chart, not specific for any code.
Screenshot 2021-01-09 141121
Note that there is 2 type of spacing here:
  1. the space you see here, (between x == 0 and x == 1). At this moment this is hardcoded to “1 column width space”
  2. the space between columns on the same x coordinate (if you have multiple series)
Change this line to:
lv_coord_t col_w = w / ((_lv_ll_get_len(&ext->series_ll) + 0) * ext->point_cnt);
This way only the 2) type of spacing will be visible and it can be adjusted with pad_inner on the series part.
Thanks kisvegabor. The chart in my picture has only a single series. Any chance extending the LVGL API to allow control of the inter bar spacing?
I plan to let platformio to manage the LVGL library so prefer not to fork it.
