Hi, Sir,
I want to change the backgroud height of a label to make the label backgroud equal to the font size. I have set the padding.ver to 1, but still have a large blank space in the vertical . I am using the lv_font_dejavu_40. Which parameter in the style might control it?
Best Regards,
It should be the padding
. Can you send a code snippet to try it?
Hi, Kisvegabor,
Many thanks!
Further test show that ,the blank space were inherited from the font itself . Am I right? Do we have some lib fonts which have not blank space in the vertical direction?
Code is as below :
static lv_style_t style1;
lv_style_copy(&style1, &lv_style_pretty );
style1.text.font = &lv_font_dejavu_30;
style1.body.main_color=LV_COLOR_GRAY ;
style1.body.grad_color =LV_COLOR_GRAY ;
style1.body.padding.ver=1;
style1.body.padding.hor=1;
style1.body.padding.inner=1;
style1.text.line_space=1;
style1.body.border.color=LV_COLOR_RED;
Best Regards,
It seems correct to me:
The extra space on the top is reserved for the accent, and on bottom for the lower part of the letters (eg y, g or j).
Hi, Kisvegabor,
Many thanks!
Yes I got the same result with you.
Best Regards,
