VisualStudio Simulator
v8
Change the color of axis (includse tick and label text)
For example, I want to have a chart with red axis and red label text.
BTW, Could the primary axis and the second be set with different color ?
set the text color of a style and add it to the chart obj.
But it does not work!
static lv_style_t style_chart_op;
lv_style_init(&style_chart_op);
lv_style_set_text_color(&style_chart_op, lv_color_make(255, 0, 0));
chart_op = lv_chart_create(parent);
//lv_obj_add_style(chart_op, &style_chart_op,0);
lv_obj_set_width(chart_op, lv_pct(92));//640
lv_obj_set_height(chart_op, lv_pct(90) );//300
lv_obj_set_style_opa(chart_op, 150, 0);
lv_obj_set_style_bg_color(chart_op, lv_color_make(200,50,10), 0);
lv_obj_set_style_bg_grad_color(chart_op, lv_color_make(10, 100, 200), 0);
lv_obj_set_style_bg_grad_dir(chart_op, LV_GRAD_DIR_VER,0);
lv_obj_set_scrollbar_mode(chart_op, LV_SCROLL_SNAP_NONE);
lv_obj_add_style(chart_op, &style_chart_op, 0);
I have modified all of the line color in chart (includes the grid line in chart)via following
else if (code == LV_EVENT_DRAW_PART_BEGIN){
lv_obj_draw_part_dsc_t* dsc_chart = lv_event_get_draw_part_dsc(e);
if (dsc_chart->part = LV_PART_TICKS) {
dsc_chart->line_dsc->color = lv_color_make(255, 0, 0);
I think that the color of label text can be set by the same way but I can not find that exactly.
But It can not set axis with different color.
Thank you very much!
