codeblock
change the color of a label
changed the code as the demo do, can’t pass compile, it says “expected expression before ‘uint16_t’”
First of all, it looks like you are trying to use a C++ cast in a C project. In C you would write it as (uint16_t)0x07e0. That’s why you are getting the error.
Second, colors in LittlevGL are lv_color_t values, not integers. You should use the lv_color_make function and pass it 3 RGB values, or (only if you know that LV_COLOR_DEPTH is 16) I think putting a uint16_t value in main_color.full might work.
