how to change the background color after the table was create?(V8)
Before posting
I need change the background color of the table after it was create. I have use ‘lv_obj_draw_part_dsc_t’ in the callback function to do this, but it seems like it creat another layer on the top and the label have been covered. The scene is when I create a table with fixed color, when I click one of cell in this table,  the background of the cell is changed and the label still on it. At this moment I do not know how to do it, I would appreciate if anyone could give me some advice!
layer
v8
click the cell of table the background color changed and the label still on it.
#include "../../lv_examples.h"
#if LV_USE_TABLE && LV_BUILD_EXAMPLES
#define ITEM_CNT 200
static void draw_event_cb(lv_event_t * e)
    /*If the cells are drawn...*/
    if(dsc->part == LV_PART_ITEMS) {
        uint32_t irow = dsc->id /  lv_table_get_col_cnt(obj);
        uint32_t icol = dsc->id - irow * lv_table_get_col_cnt(obj);
        bool chk = lv_table_has_cell_ctrl(obj, irow, icol, LV_TABLE_CELL_CTRL_CUSTOM_1);
        //bool chk = lv_table_has_cell_ctrl(obj, dsc->id, 0, LV_TABLE_CELL_CTRL_CUSTOM_1);
        if(chk)
            dsc->rect_dsc->bg_color = lv_color_hex(0x6495ED);
            //dsc->rect_dsc->bg_opa = 0;
            dsc->rect_dsc->border_width = 2;
            dsc->rect_dsc->border_color = lv_color_hex(0x6495ED);
            lv_draw_rect(dsc->draw_area, dsc->clip_area, dsc->rect_dsc);
            // dsc->label_dsc->align=LV_TEXT_ALIGN_CENTER;
            // lv_draw_label(dsc->draw_area, dsc->clip_area, dsc->label_dsc,lv_table_get_cell_value(obj,irow,icol),NULL);
            //lv_draw_label(&label_area, dsc->clip_area, &label_draw_dsc, buf, NULL);
        lv_draw_rect_dsc_t rect_dsc;
        lv_draw_rect_dsc_init(&rect_dsc);
        rect_dsc.bg_color = chk ? lv_theme_get_color_primary(obj) : lv_palette_lighten(LV_PALETTE_GREY, 2);
        rect_dsc.radius = LV_RADIUS_CIRCLE;
        lv_area_t sw_area;
        sw_area.x1 = dsc->draw_area->x2 - 50;
        sw_area.x2 = sw_area.x1 + 40;
        sw_area.y1 =  dsc->draw_area->y1 + lv_area_get_height(dsc->draw_area) / 2 - 10;
        sw_area.y2 = sw_area.y1 + 20;
        lv_draw_rect(&sw_area, dsc->clip_area, &rect_dsc);
        rect_dsc.bg_color = lv_color_white();
        if(chk) {
            sw_area.x2 -= 2;
            sw_area.x1 = sw_area.x2 - 16;
        } else {
            sw_area.x1 += 2;
            sw_area.x2 = sw_area.x1 + 16;
        sw_area.y1 += 2;
        sw_area.y2 -= 2;
static void change_event_cb(lv_event_t * e)
    uint16_t col;
    uint16_t row;
    lv_table_get_selected_cell(obj, &row, &col);
    bool chk = lv_table_has_cell_ctrl(obj, row, col, LV_TABLE_CELL_CTRL_CUSTOM_1);
    if(chk) lv_table_clear_cell_ctrl(obj, row, col, LV_TABLE_CELL_CTRL_CUSTOM_1);
    else lv_table_add_cell_ctrl(obj, row, col, LV_TABLE_CELL_CTRL_CUSTOM_1);
 * A very light-weighted list created from table
void lv_example_table_2(void)
    /*Measure memory usage*/
    lv_mem_monitor_t mon1;
    lv_mem_monitor(&mon1);
    uint32_t t = lv_tick_get();
    lv_obj_t * table = lv_table_create(lv_scr_act());
    /*Set a smaller height to the table. It'll make it scrollable*/
    lv_obj_set_size(table, 300, 200);
    lv_table_set_col_width(table, 0, 150);
    lv_table_set_row_cnt(table, ITEM_CNT); /*Not required but avoids a lot of memory reallocation lv_table_set_set_value*/
    lv_table_set_col_cnt(table, 2);
    /*Don't make the cell pressed, we will draw something different in the event*/
    lv_obj_remove_style(table, NULL, LV_PART_ITEMS | LV_STATE_PRESSED);
    uint32_t i;
    for(i = 0; i < ITEM_CNT; i++) {
        lv_table_set_cell_value_fmt(table, i, 0, "Item %d", i + 1);
    //lv_obj_align(table, LV_ALIGN_CENTER, 0, -20);
    /*Add an event callback to to apply some custom drawing*/
    lv_obj_add_event_cb(table, draw_event_cb, LV_EVENT_DRAW_PART_END, NULL);
    lv_obj_add_event_cb(table, change_event_cb, LV_EVENT_VALUE_CHANGED, NULL);
    lv_mem_monitor_t mon2;
    lv_mem_monitor(&mon2);
    uint32_t mem_used = mon1.free_size - mon2.free_size;
    uint32_t elaps = lv_tick_elaps(t);
    lv_label_set_text_fmt(label, "%d items were created in %d ms\n"
                                  "using %d bytes of memory",
                                  ITEM_CNT, elaps, mem_used);
    lv_obj_align(label, LV_ALIGN_BOTTOM_MID, 0, -10);
