Visual Studio Professional 2019, GUIGuider
9.1
I created a table using the GUIGuider software, then generate a C code to later be used in my C++ program.
I noticed that I cannot change the color of specific cell. (Probably dont know how)
I want to make the first row of my table color different than the other rows.
I tried reading the 9.1 documentation on sample source code to change table cell color.
However, the documentation generate the table from coding itself, whereas I am using generated code from GUIGuider, and trying to modify the code from my C++ program.
Is there any method to directly modify the cell color after the table has been created ?
When I tried to set the background color, it changes the whole table color.
Sorry I cannot provide a code that you can run, since I am modifying the code from my C++ program. The generated C code is only for base.
char verBuf[20];
lv_table_set_col_width(guider_ui.FWVersion_FWVersionTable, 0, 400); //change width
lv_obj_set_style_bg_color(guider_ui.FWVersion_FWVersionTable, lv_color_hex(0x2195f6), LV_PART_MAIN|LV_STATE_DEFAULT); // How to make this apply to first row only ?
lv_obj_set_style_border_color(guider_ui.FWVersion_FWVersionTable, lv_color_hex(0x2195f6), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_font(guider_ui.FWVersion_FWVersionTable, &lv_font_montserratMedium_24, LV_PART_ITEMS|LV_STATE_DEFAULT);
lv_obj_set_style_text_align(guider_ui.FWVersion_FWVersionTable, LV_TEXT_ALIGN_LEFT, LV_PART_ITEMS|LV_STATE_DEFAULT);
lv_table_set_row_cnt(guider_ui.FWVersion_FWVersionTable,9);
lv_table_set_cell_value(guider_ui.FWVersion_FWVersionTable,1,0,"Product Version");
ylib_makeVersionString(verBuf, YSIZEOF(verBuf), PRODUCT_INFO.productVersion());
lv_table_set_cell_value(guider_ui.FWVersion_FWVersionTable,1,1,verBuf);
