I have 2 tabs in tabview and are filled with symbols. Upon navigating to another tab, I want to change the symbol style.
lvgl pc sim
7.9.1
I want to use the same symbol from fontawesome with two different styles (Regular/ Filled) in each tab of tabview.
I added two fonts (Regular + Filled) with the same symbol unicode into the font converter and it combined two fonts into 1 file. I’m not quite sure how to switch between the two fonts in lvgl.
I did try to import the two styles as two separate fonts but I was not able to set the font locally to the tab1/ tab2 object.
LV_FONT_DECLARE(solid_circle_20); //Consist of both reg/filled fonts
#define SOLID_CIRCLE_20 "\uf111"
static lv_style_t style_tab;
lv_style_init(&style_tab);
lv_style_set_text_font(&style_tab, LV_STATE_DEFAULT, &solid_circle_20);
lv_obj_t *tabview = lv_tabview_create(lv_scr_act(), NULL);
lv_tabview_set_btns_pos(tabview, LV_TABVIEW_TAB_POS_BOTTOM);
lv_obj_t *tab1 = lv_tabview_add_tab(tabview, SOLID_CIRCLE_20);
lv_obj_t *tab2 = lv_tabview_add_tab(tabview, SOLID_CIRCLE_20);
