How to change spinner circular width and indication color
ARM
7
void spinner(void)
/*Create a Preloader object*/
lv_obj_t * preload = lv_spinner_create(lv_scr_act(), NULL);
lv_obj_set_size(preload, 100, 100);
lv_obj_align(preload, NULL, LV_ALIGN_CENTER, 0, 0);
To change the width I think you can just increase the object size.
To change the arc’s color set the line_color style property on LV_ARC_PART_INDIC.
Not Worked. Please find my style and object code
//style_spinner
static lv_style_t style_spinner;
lv_style_init(&style_spinner);
lv_style_set_line_color(&style_spinner,LV_SPINNER_PART_INDIC, LV_COLOR_BG);
//loader
lv_obj_t *loader=lv_spinner_create(lv_scr_act(),NULL);
lv_obj_set_size(loader,75,75);
lv_obj_add_style(loader,LV_SPINNER_PART_BG,&style_spinner);
lv_obj_align(loader,logo_title,LV_ALIGN_OUT_BOTTOM_MID,0,30);
i want decrease width of spinner. please find the attachment.
Change the line_width style property.
line_width decreased the gap but i want to decrease the width of indication also.
i tried lv_style_set_line_width(&style_spinner,LV_SPINNER_PART_INDIC, 2); but not worked.
The code you provided above is incorrect. You should be passing a state here (LV_STATE_DEFAULT), not a part.
embeddedt,
Thanks for your replay. Here i want to change indicator width and indicator color for spinner.
It won’t work if you pass a part; that’s not what the API expects (source). The part should be provided in the lv_obj_add_style (which you are doing), and the state should be provided in the lv_style_set call.
lv_style_set_line_color(&style_spinner,LV_STATE_DEFAULT, LV_COLOR_WHITE);
lv_style_set_line_width(&style_spinner,LV_SPINNER_PART_BG, 2);
//loader
lv_obj_align(loader,NULL,LV_ALIGN_CENTER,0,30);
the above code gives me below output. but spinner indicator color and indicator width not changed.
You haven’t corrected the call to lv_style_set_line_width; also you would want to change the line width on both LV_SPINNER_PART_BG and LV_SPINNER_PART_INDIC.
Thanks embeddedt. issue resolved
Glad you were able to fix it!
