How to change size of font symbol
If you use LV_SYMBOL_BARS as example or whatever symbol from font awasome that it is already build in on label or on button can you select the size of the symbol? In symbol fonts you can declare your font with specific pixel size if you create it with the font tool but how does this work with the symbols that are already build in?
esp32 simulator
8.3
able to resize symbols
tried to apply
lv_style_set_text_font function but it broke the symbol cause i assume that the symbol hex does not exist on the font list.
Set the specific font according to your desired size. The inbuilt lv_font_montserrat fonts already have the symbols
lv_obj_t * label = lv_label_create(lv_screen_active());
lv_label_set_text(label, LV_SYMBOL_BARS);
lv_obj_set_style_text_font(label, &lv_font_montserrat_48, 0);
