How to change direction of progress when progress bar is vertical?
STM32H750
V8.3.7
When the progress bar is vertical, the progress can be from top to bottom and bottom to top
I modified the example lv_example_bar_5, but it doesn’t work.
    lv_obj_t * bar_ltr = lv_bar_create(lv_scr_act());
    lv_obj_set_size(bar_ltr, 20, 200);
    lv_bar_set_value(bar_ltr, 70, LV_ANIM_OFF);
    lv_obj_align(bar_ltr, LV_ALIGN_CENTER, -50, 0);
    lv_obj_t * bar_rtl = lv_bar_create(lv_scr_act());
    lv_obj_set_style_base_dir(bar_rtl, LV_BASE_DIR_LTR, 0);
    lv_obj_set_size(bar_rtl, 20, 200);
    lv_bar_set_value(bar_rtl, 70, LV_ANIM_OFF);
    lv_obj_align(bar_rtl, LV_ALIGN_CENTER, 50, 0);
lv_obj_set_style_transform_angle(obj, 900, LV_PART_MAIN) should do the trick. The 900 is 90 degrees. 1800 = 180 and 2700 is 270
There are actually 2 ways to do it.
    lv_obj_t * bar_bot_top1 = lv_bar_create(lv_scr_act());
    lv_obj_set_size(bar_bot_top1 , 20, 200);
    lv_bar_set_value(bar_bot_top1 , 70, LV_ANIM_OFF);
    lv_obj_align(bar_bot_top1 , LV_ALIGN_CENTER, -50, 0);
    lv_obj_set_style_transform_angle(bar_bot_top1 , 900, LV_PART_MAIN)
    lv_obj_t * bar_top_bot1 = lv_bar_create(lv_scr_act());
    lv_obj_set_size(bar_top_bot1 , 20, 200);
    lv_bar_set_value(bar_top_bot1 , 70, LV_ANIM_OFF);
    lv_obj_align(bar_top_bot1 , LV_ALIGN_CENTER, -50, 0);
    lv_obj_set_style_transform_angle(bar_bot_top1 , 2700, LV_PART_MAIN)
   // and the other way is making the widget taller than it is wide.
    lv_obj_t * bar_bot_top2 = lv_bar_create(lv_scr_act());
    lv_obj_set_size(bar_bot_top2 , 200, 20);
    lv_bar_set_value(bar_bot_top2 , 70, LV_ANIM_OFF);
    lv_obj_align(bar_bot_top2 , LV_ALIGN_CENTER, -50, 0);
    lv_obj_t * bar_top_bot2 = lv_bar_create(lv_scr_act());
    lv_obj_set_style_base_dir(bar_top_bot2, LV_BASE_DIR_LTR, 0);
    lv_obj_set_size(bar_top_bot2 , 200, 20);
    lv_bar_set_value(bar_top_bot2 , 70, LV_ANIM_OFF);
    lv_obj_align(bar_top_bot2 , LV_ALIGN_CENTER, -50, 0);
