How to change cell color in table 8.3
Hi @Muzgog ,
Here is a quick ‘proof of concept’ example for you…
You can add historic entries to the table by calling the function add_history_data( ) from anywhere in your code. I have created a define to limit the size of the table #define MAX_HISTORIC_ITEMS (see the table_example.h file below). Once the maximum number of entries is reached the oldest is lost and the newest added at the bottom…
C code file(table_example.c):
 * table_example.c
 *  Created on: 29 Jun 2023
 *      Author: PeterB
#include <stddef.h>
#include <stdlib.h>
#include <stdio.h>
#include "lvgl.h"
#include "table_example.h"
static history_list_t historic_list  = { NULL, NULL, NULL, 0 };
static lv_obj_t * table;
static history_data_t *get_historic_by_idx( uint32_t idx ) {
	history_entry_t	*temp_ptr = historic_list.begin;
	for( uint32_t i = 0; i < idx; i++ ) {
		if( temp_ptr != NULL ) temp_ptr =  temp_ptr->next; else break;
	return &temp_ptr->data;
static void add_history_data( history_data_t in_data ) {
	history_entry_t	*temp_ptr;
	historic_list.history_data = lv_mem_alloc( sizeof(history_entry_t) );	// Allocate a new entry.
	if (historic_list.begin == NULL) {	  	 						// Deals with the first entry
		historic_list.begin = historic_list.history_data;
		historic_list.history_data->prev = NULL;
	} else {
		historic_list.end->next = historic_list.history_data;		// Do this after the first
		historic_list.history_data->prev = historic_list.end;
	historic_list.end = historic_list.history_data;
	historic_list.history_data->next = NULL;
	memcpy( &historic_list.end->data, &in_data, sizeof(in_data) );	// Save input to history entry
	if( ++historic_list.number_of_entries > MAX_HISTORIC_ITEMS ) {	// Limit the number of entries
		temp_ptr = historic_list.begin->next;
		lv_mem_free( historic_list.begin );
		historic_list.begin = temp_ptr;
		historic_list.begin->prev = NULL;
		historic_list.number_of_entries--;
	lv_obj_invalidate(table);
	return;
static void table_cb(lv_event_t * e) {
    lv_obj_t 				*obj = lv_event_get_target(e);
    lv_obj_draw_part_dsc_t	*dsc = lv_event_get_draw_part_dsc(e);
    history_data_t			*temp_data;
    /*If the cells are drawn...*/
    if(dsc->part == LV_PART_ITEMS) {
    	if( (lv_table_get_row_cnt( obj )-1) < historic_list.number_of_entries ) {
    	    lv_table_set_row_cnt(table, historic_list.number_of_entries + 1);   // +1 for header row
        uint32_t row = dsc->id /  lv_table_get_col_cnt(obj);
        uint32_t col = dsc->id - row * lv_table_get_col_cnt(obj);
        /*Make the texts in the first cell centre aligned with a blue background*/
        if(row == 0) {
            dsc->label_dsc->align = LV_TEXT_ALIGN_CENTER;
            dsc->rect_dsc->bg_color = lv_color_mix(lv_palette_main(LV_PALETTE_BLUE), dsc->rect_dsc->bg_color, LV_OPA_20);
            dsc->rect_dsc->bg_opa = LV_OPA_COVER;
        } else {
        	temp_data = get_historic_by_idx( row - 1 );
        	int *temp_val_p;
        	switch( col ) {
        		case 0:
        			temp_val_p = &temp_data->oil;
        			break;
        		case 1:
        			temp_val_p = &temp_data->battery;
        			break;
        		case 2:
        			temp_val_p = &temp_data->performance;
        			break;
        	printf( "row: %d\r\n", row);
        	fflush( stdout );
			if(*temp_val_p < 30) {
				dsc->label_dsc->color = lv_palette_main(LV_PALETTE_RED);
			} else if(*temp_val_p >= 30 && *temp_val_p <= 70) {
				dsc->label_dsc->color = lv_palette_main(LV_PALETTE_AMBER);
			} else {
			   dsc->label_dsc->color = lv_palette_main(LV_PALETTE_GREEN);
        	lv_table_set_cell_value_fmt(table, row, col, "%d", *temp_val_p );
void timer_cb( lv_timer_t * timer ) {
	history_data_t new_data;
    new_data.oil = rand() % 100;
    new_data.battery = rand() % 100;
    new_data.performance = rand() % 100;
    add_history_data( new_data );
void create_table(lv_obj_t * parent) {
    table = lv_table_create(parent);
    lv_table_set_col_cnt(table, 3);
    lv_table_set_row_cnt(table, 1);
    lv_obj_align(table, LV_ALIGN_CENTER, 0, 0);
    /*Setup columns*/
    lv_table_set_cell_value( table, 0, 0, "Oil level" );
    lv_table_set_col_width(table, 0, 140);
    lv_table_set_cell_value( table, 0, 1, "Battery level" );
    lv_table_set_col_width(table, 1, 140);
    lv_table_set_cell_value( table, 0, 2, "Performance" );
    lv_table_set_col_width(table, 2, 140);
    lv_obj_set_size( table, 420, 500 );
    lv_obj_update_layout( table );
    lv_obj_add_event_cb(table, table_cb, LV_EVENT_DRAW_PART_BEGIN, NULL);
    /* A timer to generate some random table data */
    lv_timer_create( timer_cb, 2000, NULL );
C Header File(table_example.h):
 * table_example.h
 *  Created on: 30 Jun 2023
 *      Author: PeterB
#ifndef TABLE_EXAMPLE_H_
#define TABLE_EXAMPLE_H_
#define MAX_HISTORIC_ITEMS		10
typedef struct _history_data {
	int oil;
	int battery;
	int performance;
} history_data_t;
typedef struct history_entry_t 	history_entry_t;
struct history_entry_t {
	history_entry_t	*next;
	history_entry_t	*prev;
	history_data_t	data;
typedef struct _history_list {
	history_entry_t 	*begin;
	history_entry_t		*end;
	history_entry_t		*history_data;
	uint32_t			number_of_entries;
} history_list_t;
void create_table(lv_obj_t * parent);
#endif /* TABLE_EXAMPLE_H_ */
To use the example create the c code file and the header file and add them to your project and call create_table(lv_scr_act());
Here’s a screen shot:
table
I hope this helps…
Kind Regards,
Pete
