Description : I need to change the color of a cell based on its value(lets ignore the logic for now)
ESP32S3 TFT parallel 3.5 w/ touch. Link: ESP32-S3 Parallel TFT with Touch 3.5'' ILI9488 | Makerfabs using ESP-IDF on Vscode
What LVGL version are you using? 8.3
What do you want to achieve? Change the color of a cell. either the text or the box itself
What have you tried so far? lv_table_set_cell_type(which is deprecated)
void create_table(lv_obj_t * parent/*parent screen*/)
lv_obj_t * table = lv_table_create(parent);
lv_table_set_col_cnt(table, 2);
lv_table_set_row_cnt(table, 4);
lv_obj_align(table, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_pos(table,0,100);
CONVERSION PROCESS... VERY LONG.... HAS TO BE A QUICKER WAY
char text[10];
sprintf(text, "%d", oil_1);
const char* char_oil_1 = text;
char text2[10];
sprintf(text2, "%d", oil_2);
const char* char_oil_2 = text2;
char text3[10];
sprintf(text3, "%d", battery_1);
const char* char_battery_1 = text3;
char text4[10];
sprintf(text4, "%d", battery_2);
const char* char_battery_2 = text4;
char text5[10];
sprintf(text5, "%d", performance_1);
const char* char_performance_1 = text5;
char text6[10];
sprintf(text6, "%d", performance_2);
const char* char_performance_2 = text6;
// Define the cell styles
static lv_style_t style_red;
static lv_style_t style_yellow;
static lv_style_t style_green;
/*Fill the first column*/
lv_table_set_cell_value(table, 0, 0, "Oil level");
lv_table_set_cell_value(table, 1, 0, char_oil_1);
lv_table_set_cell_value(table, 2, 0, char_oil_2);
//lv_table_set_cell_value(table, 3, 0, "Citron");
/*Fill the second column*/
lv_table_set_cell_value(table, 0, 1, "Battery level");
lv_table_set_cell_value(table, 1, 1, char_battery_1);
lv_table_set_cell_value(table, 2, 1, char_battery_2);
// lv_table_set_cell_value(table, 3, 1, "$6");
lv_table_set_cell_value(table, 0, 2, "Performance");
lv_table_set_cell_value(table, 1, 2, char_performance_1);
lv_table_set_cell_value(table, 2, 2, char_performance_2);
lv_obj_set_size(table,320,250);
// Apply the styles to the cells based on the cell value conditions
for (uint16_t row = 1; row <= 2; row++) {
for (uint16_t col = 0; col <= 2; col++) {
const char* cell_value = lv_table_get_cell_value(table, row, col);
int value = atoi(cell_value);
if (value < 30) {
/*where new method goes*/ // lv_table_set_cell_type(table, row,col,1);
} else if (value >= 30 && value <= 70) {
/*where new method goes*/ //lv_table_set_cell_type(table, row,col,2);
} else {
/*where new method goes*/ // lv_table_set_cell_type(table, row,col,3);
Variables are define as global variables ex:
int oil_1 = 64;
int oil_2 = 32;
int battery_1 = 50;
int battery_2 = 11;
int performance_1 = 56;
int performance_2 = 90;
