How to change buttons' bg-properties of a list when pressed?
Hi,I’ve been trying to test widget list recently,and I want to do some custom effects.But,I found that I cannot change the bg color and bg opacities of buttons wrapped by list to be same with labels’ above.I don;t know why and I want to figure out.
Results from simulator and real device are the same.
released V8.3.0
Change styles.
 lv_obj_t *list = lv_list_create(lv_scr_act());
    static lv_style_t style_label, style_btn;
    lv_style_init(&style_label);
    lv_style_init(&style_btn);
    lv_style_set_bg_color(&style_label, lv_palette_main(LV_PALETTE_CYAN));
    lv_style_set_bg_opa(&style_label, LV_OPA_50);
    lv_style_set_bg_color(&style_btn, lv_palette_main(LV_PALETTE_CYAN));
    lv_style_set_bg_opa(&style_btn, LV_OPA_50);
    lv_style_set_opa(&style_btn, LV_OPA_COVER);
    lv_style_set_text_color(&style_btn, lv_color_white());
    lv_obj_t *list_item;
    list_item = lv_list_add_text(list, "Start");
    lv_obj_add_style(list_item, &style_label, 0);
    list_item = lv_list_add_btn(list, LV_SYMBOL_BATTERY_FULL, "Full Battery");
    lv_obj_add_style(list_item, &style_btn, LV_STATE_PRESSED);
    // lv_obj_add_event_cb(list_item, test_list1_pressed_cb, LV_EVENT_PRESSED, NULL);
    list_item = lv_list_add_btn(list, LV_SYMBOL_BATTERY_3, "3 Battery");
    list_item = lv_list_add_btn(list, LV_SYMBOL_BATTERY_2, "2 Battery");
    list_item = lv_list_add_btn(list, LV_SYMBOL_BATTERY_1, "1 Battery");
    list_item = lv_list_add_btn(list, LV_SYMBOL_BATTERY_EMPTY, "Empty Battery");
    list_item = lv_list_add_text(list, "End");
    list_item = lv_list_add_btn(list, LV_SYMBOL_CLOSE, "End Exist");
As above,you can see the first button’s bg color is not same with the first label’s.And text color of the button seems like not so pure white.
Hi @Pingye007,
Thank you for sending a message.
Considering your situation, I recommend using : lv_obj_set_style_bg_opa(item, 0, 0);
This sets the background opacity of each list button to fully transparent (0 ), which effectively makes the button background invisible.
You’re applying style_btn only to LV_STATE_PRESSED , but the style contains lv_style_set_opa() and lv_style_set_text_color() which you likely want visible in the default state too. Also, the theme’s bg_color_white style on buttons will override your LV_OPA_50 cyan.
