Version:
lv_micropython version is 7.11.
Board:
OEM board with STM43H743 mcu.
Problem:
The width of Button can not be changed. In the past version, the width of button could be adjusted automaticly with text label. But from the version 7.10, the button could not be changed the width.
The code:
The code is from the example.
def event_handler(source,evt):
if evt == lv.EVENT.CLICKED:
if source == btn1:
#treat “clicked” events only for btn1
print(“Clicked”)
elif evt == lv.EVENT.VALUE_CHANGED:
print(“Toggled”)
#create a simple button
btn1 = lv.btn(lv.scr_act(),None)
#attach the callback
btn1.set_event_cb(event_handler)
btn1.align(None,lv.ALIGN.CENTER,0,-40)
label=lv.label(btn1,None)
label.set_text(“Buttkkjjjon”)
#create a toggle button
btn2 = lv.btn(lv.scr_act(),None)
btn2.set_event_cb(event_handler)
btn2.align(None,lv.ALIGN.CENTER,0,40)
btn2.set_checkable(True)
btn2.toggle()
#btn2.set_fit2(lv.FIT.NONE,lv.FIT.TIGHT)
label=lv.label(btn2,None)
label.set_text(“Toggled”)
