STM32F207xx
LVGL v8.3
I want to add a custom image to use the arc widget as a thermostat setpoint widget.
I want to use 2 images background and foreground, when the setpoint changes, the foreground image should be drawn frontend the background image.
There is an example screen that I want to create. I created this screen by using another GUI framework.
I should use LVGL this time.
I examined the examples but I am a newbie for LVGL. I don’t understand how I can do that or it is possible in LVGL.
Try image with full circle size. Ofcourse bottom empty.
Arc object require define full circle area, but you can dont use it and place it invisible or under other objects.
