How to capture the whole screen? I want a screenshot then I want to save it as a file, like png etc.
Have a look at this blog post, as it is still relevant and explains the steps needed to capture the screen. I used that post to transfer the picture as a BMP image either to a webclient or to a file like this:
static void gui_take_screenshot(uint8_t * data_p, size_t len)
size_t res = 0;
switch(guiSnapshot) {
case 1:
res = pFileOut.write(data_p, len);
break;
case 2:
res = webClient->client().write(data_p, len);
break;
default:
res = 0; // nothing to do
if(res != len) {
Log.warning(F("GUI: Pixelbuffer not completely sent"));
static void IRAM_ATTR tft_espi_flush(lv_disp_drv_t * disp, const lv_area_t * area, lv_color_t * color_p)
size_t len = (area->x2 - area->x1 + 1) * (area->y2 - area->y1 + 1); /* Number of pixels */
/* Update TFT */
tft.startWrite(); /* Start new TFT transaction */
tft.setWindow(area->x1, area->y1, area->x2, area->y2); /* set the working window */
tft.setSwapBytes(true); /* set endianess */
tft.pushPixels((uint16_t *)color_p, len); /* Write words at once */
tft.endWrite(); /* terminate TFT transaction */
/* Send Screenshot data */
if(guiSnapshot != 0) {
gui_take_screenshot((uint8_t *)color_p, len * sizeof(lv_color_t)); /* Number of bytes */
/* Tell lvgl that flushing is done */
lv_disp_flush_ready(disp);
A bitmap file doesn’t require encoding of the image data, it only needs a header that describes the bytes that follow.
Then you can take a screenshot like this:
void guiTakeScreenshot(const char * pFileName)
pFileOut = SPIFFS.open(pFileName, "w");
if(pFileOut == 0) {
Log.warning(F("GUI: %s cannot be opened"), pFileName);
return;
guiSnapshot = 1;
guiSendBmpHeader();
lv_obj_invalidate(lv_scr_act());
lv_refr_now(NULL); /* Will call our disp_drv.disp_flush function */
guiSnapshot = 0;
pFileOut.close();
Log.verbose(F("[Display] data flushed to %s"), pFileName);
