STM32F407ZGT6
How to use the button type input device normally in the interface
By referring to the “lv_port_indev_template.c” file, I completed the docking of the button reading between LVGL and MCU, and set the analog point corresponding to the button. However, when I tested pressing these buttons, I found that these simulated points did not show any signs of being pressed. I suspect that because LVGL did not call the button scan without updating, but this is just my guess, I hope to find the answer as soon as possible
void lv_port_indev_init(void)
lv_indev_drv_t indev_drv;
* Button
/*Initialize your button if you have*/
button_init();
/*Register a button input device*/
indev_drv.type = LV_INDEV_TYPE_BUTTON;
indev_drv.read_cb = button_read;
indev_button = lv_indev_drv_register(&indev_drv);
/*Assign buttons to points on the screen*/
static const lv_point_t btn_points[2] = {
{64, 32}, /*Button 0 -> x:10; y:10*/
{32, 64}, /*Button 1 -> x:40; y:100*/
lv_indev_set_button_points(indev_button, btn_points);
