All use C, and the storage occupied by global variables used by the business is too large,So I want to take CPP to complete it.
When C99 is checked, many errors are prompted when compiling the cpp file. After canceling C99, compiling lv_color.h file prompts many errors.
How to be compatible with C++ on the STM32 platform?
STM32F429,ARM Compiler V5
V7.3.0
Using arm compiler V5, I can compile littlevgl and C++.
Compile LVGL as C code and the rest of your code as C++. We don’t support compiling LVGL files as C++, but including its headers in a C++ file should work without problems.
Please make sure you are using the latest version of LVGL from release/v7 or master - there have been fixes for C++ builds in the recent past.
I just tried it with lvgl V7.5.0, in the CPP file #include “lvgl.h”, some errors will be reported
The lvgl.h in lvgl-master folder.
In this CPP file, I only used the method in lv_mem.h
Change to include “src/lv_misc/lv_mem.h” and there is no problem.
But in the place where the widget is displayed, I cannot avoid this problem
Looking like you use an old version of c++ standard, try to change ARM Compiler version to 6 on page “Target” and language for C++ on page “C/C++ (AC)” to c++11 or newer
Also, I’ll make my macro _LV_COLOR_MAKE_TYPE_HELPER more compatible with Keil c++98 compiler. But to fix other errors you need change ARM Compiler version from 5 to 6
Thanks~
In order to be compatible with C++98, I also modified LV_COLOR_MAKE.The code I modified is not very good
Upgrade to v6, some compilation instructions also need to be changed…And I am also worried that the file compiled by v6 is larger than V5.
By the way, how do you set the event callback function elegantly in CPP?
Like this?
class CWnd
public:
static void CWnd_defEventCB(lv_obj_t * obj, lv_event_t e);
You can check my pull request https://github.com/lvgl/lvgl/pull/1788
There fixed compilation with ARM Compiler version 6.
About callbacks, for example usage of lv_task_create:
C++ 98 way:
class SomeClass
public:
void someFunction()
lv_task_create(&SomeClass::taskCallback, 500, LV_TASK_PRIO_MID, this);
private:
void makeSomething()
printf("something");
static void taskCallback(lv_task_t* task)
SomeClass* self = reinterpret_cast<SomeClass*>(task->user_data);
self->makeSomething();
C++11 way using lambda:
class SomeClassCpp11
public:
void someFunction()
lv_task_create([](auto task)
auto self = reinterpret_cast<SomeClassCpp11*>(task->user_data);
}, 500, LV_TASK_PRIO_MID, this);
private:
Thanks for your reply.Got it!
1.Class’s static member function~
2.pass “this” to “user data” when creating the task…
But the event call back of the control(eg:button) is a bit different.
Event callback for the control is similar:
class ButtonWrapper
public:
ButtonWrapper()
button_ = lv_btn_create(lv_scr_act(), NULL);
lv_obj_set_event_cb(button_, &ButtonWrapper::buttonCallback);
lv_obj_set_user_data(button_, this);
~ButtonWrapper()
lv_obj_del(button_);
private:
void eventHandler(lv_event_t event)
switch(event)
case LV_EVENT_PRESSED:
printf("ButtonWrapper pressed\n");
break;
static void buttonCallback(lv_obj_t* obj, lv_event_t event)
ButtonWrapper* self = reinterpret_cast<ButtonWrapper*>(lv_obj_get_user_data(obj));
self->eventHandler(event);
private:
lv_obj_t* button_;
Hi! I am using LVGL version 8.3.1 and after my “adapting” the code, I get an error:
argument of type "void(*)(lv_obj_t *obj, lv_event_t *event)" incompatible with the "lv_event_cb_t" type parameter
class ButtonWrapper
public:
ButtonWrapper()
button_ = lv_btn_create(lv_scr_act());
lv_obj_add_event_cb(button_, &ButtonWrapper::buttonCallback, LV_EVENT_VALUE_CHANGED, NULL); // <----------- The error is here
~ButtonWrapper()
private:
void eventHandler(lv_event_t *e)
switch (code)
break;
static void buttonCallback(lv_obj_t *obj, lv_event_t *event)
ButtonWrapper *self = reinterpret_cast<ButtonWrapper *>(lv_obj_get_user_data(obj));
private:
lv_obj_t *button_;
Please help to adapt the code.
1st:
class ButtonWrapper
public:
ButtonWrapper()
~ButtonWrapper()
private:
void eventHandler(lv_event_t* e)
switch (code)
break;
static void buttonCallback(lv_event_t* e)
self->eventHandler(e);
private:
lv_obj_t* button_;
2nd:
class ButtonWrapper
public:
ButtonWrapper()
lv_obj_add_event_cb(button_, &ButtonWrapper::buttonCallback, LV_EVENT_VALUE_CHANGED, this);
~ButtonWrapper()
private:
static void eventHandler(lv_event_t* e)
switch (code)
break;
ButtonWrapper* self = reinterpret_cast<ButtonWrapper*>(lv_event_get_user_data(e));
private:
lv_obj_t* button_;
