Raspberry Pi 4, genuine Raspberry 7" Touch Display attached (as “DSI-1”).
My Raspberry Pi app is Touch-operated (Display = “Touch Event Device”).
7" Display rotated 180 degrees. The app works fine but . . .
lv_drv_conf.h needs modifications depending on attached USB KB and Mouse.
- No USB KB + MS attached, use: #define EVDEV_NAME “/dev/input/event2”
- I F USB KB + MS attached, use: #define EVDEV_NAME “/dev/input/event6”
So, if app compiled for no KB + MS boots with KB+MS attached, it gets no touch events.
This creates a lot of hassle when testing with/without KB + MS.
Raspberry Pi 4.
Windows 10 + MinGW64 Cross Compile setup using GCC compiler.
v. 8.3.0
To have the App auto-detect and use the Touch Event Device regardless attached USB -devices.
Not tried but noticed in lv_drv_conf.h:
#if USE_LIBINPUT || USE_BSD_LIBINPUT
/*If only a single device of the same type is connected, you can also auto detect it, e.g.:
*#define LIBINPUT_NAME libinput_find_dev(LIBINPUT_CAPABILITY_TOUCH, false)*/
# define LIBINPUT_NAME "/dev/input/event0" /*You can use the "evtest" Linux tool to get the list of devices and test them*/
#endif /*USE_LIBINPUT || USE_BSD_LIBINPUT*/
Questions
- Can this LIBINPUT stuff be used for auto-detecting the current Touch Event Device?
- If so, how to enable, supporting the 180 degrees rotated display (no documentation found)?
BR JJ
