How to apply "disabled" styling to checkbox text via theme
How to apply “disabled” styling to checkbox text via theme
Teensy 4.1 and GCC 9
8.0.1
World domination. And greyed-out checkbox text
Using the default theme in 8.0.1, the following:
lv_obj_add_state(btn, LV_STATE_DISABLED);
appears to apply the grey filter to the button and the label associated with the button. However, when the disabled state is applied to a checkbox, only the box itself is affected, not the checkbox text.
The default theme for the button has:
lv_obj_add_style(obj, &styles->disabled, LV_STATE_DISABLED);
but the checkbox has:
lv_obj_add_style(obj, &styles->disabled, LV_PART_INDICATOR | LV_STATE_DISABLED);
Up until now, this makes sense to me, expected behavior. However, if I try adding either of these lines to the checkbox styling in lv_theme_default.c:
lv_obj_add_style(obj, &styles->disabled, LV_PART_MAIN | LV_STATE_DISABLED);
It does not have an impact on the checkbox text. What am I missing?
(If I add text_color to &styles->disabled, this is applied to the checkbox text due to the above lines, so I feel like the style is being applied to the checkbox text)
Hi @egonbeermat ,
When applied to LV_PART_INDICATOR, it greys out the tick box. When applied to the whole object (button), it affects the entire widget including its label because the button’s label is a child that inherits opacity.
You can try :
lv_style_set_text_opa(&theme->styles.disabled, LV_OPA_40);
or
lv_obj_set_style_text_opa(obj, LV_OPA_40, LV_PART_MAIN | LV_STATE_DISABLED);
