So I’ve been dealing with this issue for awhile now and need some serious guidance on how to resolve it. I’m currently running LVGL on a Alientek Dev board utilizing an STM32H7 to drive a 1020x600 px display but cannot allocate enough memory to create an array large enough to actually fill the entire screen. At best I can render maybe 1020x200px which does indeed display the LVGL demo I have running, so LVGL’s APIs appear to be working as expected.
STM32H7 with the most recent version of LVGL.
LVGL is indeed running and working, I just need direction on how to properly allocate memory and or write/update the flash so I can utilize an array large enough to actually fill the entire screen.
Using a secondary array allocated to a separate memory address to write. This sort of worked but I was getting an issue with the alpha were I couldn’t contain the layer to a set section of the screen so the layer behind it wasn’t visible unless I set the alpha way down which makes the image dark and difficult to read.
Attempting to setup DMA and use the SDRAM I know is one the board, configuring the FMC did not work. I also confirmed that the hardware is consistent as it matches the pinout provided in my documentation.
This is all I am currently doing to update the image.
*(__IO uint16_t*) (hltdc.LayerCfg[0].FBStartAdress + (2*(Ypos*1040 + Xpos))) = (uint16_t)RGB_Code;
* @attention
* <h2><center>© Copyright (c) 2020 STMicroelectronics.
* All rights reserved.</center></h2>
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
/* Entry Point */
ENTRY(Reset_Handler)
/* Highest address of the user mode stack */
_estack = ORIGIN(RAM_D1) + LENGTH(RAM_D1); /* end of "RAM_D1" Ram type memory */
_Min_Heap_Size = 0x200 ; /* required amount of heap */
_Min_Stack_Size = 0x400 ; /* required amount of stack */
/* Memories definition */
MEMORY
DTCMRAM (xrw) : ORIGIN = 0x20000000, LENGTH = 128K
ITCMRAM (xrw) : ORIGIN = 0x00000000, LENGTH = 64K
RAM_D1 (xrw) : ORIGIN = 0x24000000, LENGTH = 512K
RAM_D2 (xrw) : ORIGIN = 0x30000000, LENGTH = 288K
RAM_D3 (xrw) : ORIGIN = 0x38000000, LENGTH = 64K
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1408K
DATA (xrw) : ORIGIN = 0x080E0000, LENGTH = 640K
```c
