can lvgl set several objects aligned with Horizontal/Vertical equidistant?
For example, if I create a container, then add 10 buttons in container. I want to align buttons with horizontal equidistant. That means the distance between adjacent button is identical.
Set LV_FIT_TIGHT to the container.
and set LV_LAYOUT_ROW_M to the container (for horizontal)
or set LV_LAYOUT_COL_M to the container (for vertical)
and set padding.inner transparent-tight style for the container
Document
Example
void btn_cont_create() {
lv_obj_t* cont;
lv_obj_t* btn[3];
lv_obj_t* label[3];
static const char* text[] = {"A", "B", "C" };
cont = lv_cont_create(lv_scr_act(),NULL);
lv_obj_align(cont, NULL, LV_ALIGN_CENTER,0,0);
lv_obj_set_auto_realign(cont, true);
lv_cont_set_layout(cont, LV_LAYOUT_ROW_M);
lv_cont_set_fit(cont, LV_FIT_TIGHT);
static lv_style_t style_cont;
lv_style_copy(&style_cont, &lv_style_transp_tight);
lv_obj_set_style(cont, &style_cont);
style_cont.body.padding.inner = 15;
for(int i = 0; i < 3; i++){
btn[i] = lv_btn_create(cont, NULL);
lv_obj_set_width(btn[i], 60 );
label[i] = lv_label_create(btn[i], NULL);
lv_label_set_text(label[i], text[i]);
Result
