i try to place a text label direct under the Image button, so I guess the best option to do it is to use LV_ALIGN_OUT_BOTTOM_MID. But it doesn’t work with my source code. Here it is:
LV_IMG_DECLARE(pic1);
imgbtn1 = lv_imgbtn_create(main_row, NULL);
lv_imgbtn_set_src(imgbtn1, LV_BTN_STATE_RELEASED, &pic1);
lv_obj_add_style(imgbtn1, LV_STATE_PRESSED, &style_pr);
lv_obj_set_size(imgbtn1, 140, 140);
lv_obj_t *label1 = lv_label_create(main_row4, NULL);
lv_obj_add_style(label1, LV_OBJ_PART_MAIN, &style_btn);
lv_label_set_text(label1, "NORMAL");
lv_obj_align(label1, NULL, LV_ALIGN_OUT_BOTTOM_MID, 0, 0);
lv_label_set_align(label1, LV_LABEL_ALIGN_CENTER);
I also have tried it with: lv_obj_align_mid_y(label1, NULL, LV_ALIGN_IN_BOTTOM_MID, 50);
But was not successful either. The label stays in the middle of the button:
The style of the label has not much action inside:
static lv_style_t style_btn;
lv_style_set_text_color(&style_btn, LV_STATE_DEFAULT, LV_COLOR_WHITE);
lv_style_set_text_font(&style_btn, LV_STATE_DEFAULT, &lv_font_montserrat_30);
Windows simulator
v7.11
Get a label to be placed under the Image button
I am not sure how your code is even compiling.
That’s wrong. that function only takes 4 parameters.
void lv_obj_align(struct _lv_obj_t *obj, lv_align_t align, lv_coord_t x_ofs, lv_coord_t y_ofs)
Change the alignment of an object and set new coordinates. Equivalent to: lv_obj_set_align(obj, align); lv_obj_set_pos(obj, x_ofs, y_ofs);
Parameters
obj -- pointer to an object to align
align -- type of alignment (see 'lv_align_t' enum) LV_ALIGN_OUT_... can't be used.
x_ofs -- x coordinate offset after alignment
y_ofs -- y coordinate offset after alignment
I am seeing 5 parameters in your call to that function. You need to remove the NULL parameter.
Sorry, but you are wrong. lv_obj_align has exactly 5 parameters in ver.7.11:
void lv_obj_align(lv_obj_t *obj, const lv_obj_t *base, lv_align_t align, lv_coord_t x_ofs, lv_coord_t y_ofs)
I wouldn’t post here a wrong code which can’t be compiled.
I didn’t realize that version 7 had 5 parameters.
Well I would think that the align works in the same manner for the most part. The label you are attempting to align is not a child of the button and as such it is probably not going to align to the button using the function in the manner that you are.
lv_obj_t *label1 = lv_label_create(imgbtn1, NULL);
Try this code and see if it solves your issue.
