How to adjust the spacing between bars
Currently I am using MicroPython, I am going to use C.
master
I want to adjust the bar spacing within the chart.
##### startup script #####
import lvgl as lv
import display_driver
##### main script #####
def draw_event_cb(e):
    dsc = lv.obj_draw_part_dsc_t.__cast__(e.get_param())
    if dsc.part == lv.PART.TICKS and dsc.id == lv.chart.AXIS.PRIMARY_X:
        time = ["01", "02", "03", "04", "05", "06", "07", "08", "09", "10", "11", "12","13","14","15","16","17","18","19","20","21","22","23","24"]
        dsc.text = bytes(time[dsc.value],"ascii")
# Add ticks and labels to the axis and demonstrate scrolling
# Create a chart
chart = lv.chart(lv.scr_act())
chart.set_size(350, 150)
chart.center()
chart.set_type(lv.chart.TYPE.BAR)
chart.set_range(lv.chart.AXIS.PRIMARY_Y, 10, 100)
chart.set_point_count(24)
chart.add_event_cb(draw_event_cb, lv.EVENT.DRAW_PART_BEGIN, None)
# Add ticks and label to every axis
chart.set_axis_tick(lv.chart.AXIS.PRIMARY_X, 0, 0, 24, 1, True, 24)
# Zoom in a little in X
#chart.set_zoom_x(300)
# Add two data series
ser1 = lv.chart.add_series(chart, lv.palette_lighten(lv.PALETTE.GREEN, 2), lv.chart.AXIS.PRIMARY_Y)
# Set the next points on 'ser1'
chart.set_next_value(ser1,00)
chart.set_next_value(ser1,10)
chart.set_next_value(ser1,20)
chart.set_next_value(ser1,30)
chart.set_next_value(ser1,40)
chart.set_next_value(ser1,50)
chart.set_next_value(ser1,60)
chart.set_next_value(ser1,70)
chart.set_next_value(ser1,80)
chart.set_next_value(ser1,90)
chart.refresh()  # Required after direct set
ex)
I do not read&write English well.
I rely on Google Translate.
Thx
I solved it.
chart.set_style_pad_column(-1, 0) /
void lv_obj_set_style_pad_column(struct _lv_obj_t *obj, lv_coord_t value, lv_style_selector_t selector)
