How to add symbols/icons to font
I have been following this guide on how to add symbols:
Add Symbols
I can use the built in symbols fine but when I try to add a new symbol, it does not display on the screen. I have even set the style for the label which uses the font but it still does not display.
Post the code (part of the code) so we can see where the problem is.
mute_symbol.c
 * Size: 16 px
 * Bpp: 4
 * Opts: --bpp 4 --size 16 --no-compress --font FontAwesome5-Solid+Brands+Regular.woff --range 63145 --format lvgl -o mute_symbol.c
#ifdef LV_LVGL_H_INCLUDE_SIMPLE
#include "lvgl.h"
#else
#include "lvgl/lvgl.h"
#ifndef MUTE_SYMBOL
#define MUTE_SYMBOL 1
#if MUTE_SYMBOL
 *    BITMAPS
/*Store the image of the glyphs*/
static LV_ATTRIBUTE_LARGE_CONST const uint8_t glyph_bitmap[] = {
    /* U+F6A9 "" */
    0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
    0x0, 0x0, 0x0, 0x8, 0xd0, 0x0, 0x0, 0x0,
    0x0, 0x0, 0x0, 0x8, 0xff, 0x0, 0x0, 0x0,
    0x0, 0x0, 0x0, 0x8, 0xff, 0xf0, 0x0, 0x0,
    0x0, 0x0, 0xdf, 0xff, 0xff, 0xff, 0x0, 0x7c,
    0x11, 0xc7, 0xf, 0xff, 0xff, 0xff, 0xf0, 0xc,
    0xfd, 0xdf, 0xc0, 0xff, 0xff, 0xff, 0xff, 0x0,
    0x1d, 0xff, 0xd1, 0xf, 0xff, 0xff, 0xff, 0xf0,
    0x1, 0xdf, 0xfd, 0x10, 0xff, 0xff, 0xff, 0xff,
    0x0, 0xcf, 0xdd, 0xfc, 0xd, 0xff, 0xff, 0xff,
    0xf0, 0x7, 0xc1, 0x1c, 0x70, 0x0, 0x0, 0x9f,
    0xff, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
    0x9f, 0xf0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
    0x0, 0x8d, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
 *  GLYPH DESCRIPTION
static const lv_font_fmt_txt_glyph_dsc_t glyph_dsc[] = {
    {.bitmap_index = 0, .adv_w = 0, .box_w = 0, .box_h = 0, .ofs_x = 0, .ofs_y = 0} /* id = 0 reserved */,
    {.bitmap_index = 0, .adv_w = 256, .box_w = 17, .box_h = 14, .ofs_x = 0, .ofs_y = -1}
 *  CHARACTER MAPPING
/*Collect the unicode lists and glyph_id offsets*/
static const lv_font_fmt_txt_cmap_t cmaps[] =
        .range_start = 63145, .range_length = 1, .glyph_id_start = 1,
        .unicode_list = NULL, .glyph_id_ofs_list = NULL, .list_length = 0, .type = LV_FONT_FMT_TXT_CMAP_FORMAT0_TINY
 *  ALL CUSTOM DATA
#if LVGL_VERSION_MAJOR == 8
/*Store all the custom data of the font*/
static  lv_font_fmt_txt_glyph_cache_t cache;
#if LVGL_VERSION_MAJOR >= 8
static const lv_font_fmt_txt_dsc_t font_dsc = {
#else
static lv_font_fmt_txt_dsc_t font_dsc = {
    .glyph_bitmap = glyph_bitmap,
    .glyph_dsc = glyph_dsc,
    .cmaps = cmaps,
    .kern_dsc = NULL,
    .kern_scale = 0,
    .cmap_num = 1,
    .bpp = 4,
    .kern_classes = 0,
    .bitmap_format = 0,
    .cache = &cache
 *  PUBLIC FONT
/*Initialize a public general font descriptor*/
const lv_font_t mute_symbol = {
#else
    .get_glyph_dsc = lv_font_get_glyph_dsc_fmt_txt,    /*Function pointer to get glyph's data*/
    .get_glyph_bitmap = lv_font_get_bitmap_fmt_txt,    /*Function pointer to get glyph's bitmap*/
    .line_height = 14,          /*The maximum line height required by the font*/
    .base_line = 1,             /*Baseline measured from the bottom of the line*/
#if !(LVGL_VERSION_MAJOR == 6 && LVGL_VERSION_MINOR == 0)
    .subpx = LV_FONT_SUBPX_NONE,
#if LV_VERSION_CHECK(7, 4, 0) || LVGL_VERSION_MAJOR >= 8
    .underline_position = -6,
    .underline_thickness = 1,
    .dsc = &font_dsc,          /*The custom font data. Will be accessed by `get_glyph_bitmap/dsc` */
#if LV_VERSION_CHECK(8, 2, 0) || LVGL_VERSION_MAJOR >= 9
    .fallback = NULL,
    .user_data = NULL,
#endif /*#if MUTE_SYMBOL*/
ui.h
LV_FONT_DECLARE(mute_symbol);
#define LV_SYMBOL_MUTED "\xEF\x9A\xA9"
MainScreen.c
USAGE
    ui_icon_mute = lv_label_create(btn);
    lv_obj_set_width(ui_icon_mute, LV_SIZE_CONTENT);
    lv_obj_set_height(ui_icon_mute, LV_SIZE_CONTENT);
    lv_obj_set_align(ui_icon_mute, LV_ALIGN_CENTER);
    lv_obj_set_style_text_color(ui_icon_mute, lv_color_hex(0x000000), LV_PART_MAIN | LV_STATE_DEFAULT);
    lv_obj_set_style_text_opa(ui_icon_mute, 255, LV_PART_MAIN | LV_STATE_DEFAULT);
    lv_obj_set_style_text_align(ui_icon_mute, LV_TEXT_ALIGN_CENTER, LV_PART_MAIN | LV_STATE_DEFAULT);
    static lv_style_t style;
    lv_style_init(&style);
    lv_style_set_text_font(&style, &mute_symbol);
    lv_obj_add_style(ui_icon_mute, &style, LV_PART_MAIN);
    lv_label_set_text(ui_icon_mute, LV_SYMBOL_MUTED);
Actually i got it to work
