Hi @JamesJJ,
I can confirm the API does not provide those functions. You would need to manage this within your own code.
Here is an alphabetical sorted process list implementation from one of my old V7 projects to give you some idea of how you could go about managing the table implementation.
extern shared_memp_t shmem_p;
extern config_dat_p_t confp;
static lv_obj_t *tsk_table0;
static lv_obj_t *tsk_table1;
static lv_obj_t *cpu0_label;
static lv_obj_t *cpu1_label;
#define NUM_COLUMNS 5
static int compare_proc_name( void *a, void *b ) {
OurTaskStatus_t *taska = (OurTaskStatus_t*)a;
OurTaskStatus_t *taskb = (OurTaskStatus_t*)b;
return( strcmp( taska->pcTaskName, taskb->pcTaskName ));
static void update_task_tables( uint8_t cpu_id, lv_obj_t *tsk_table ) {
TaskStatus_t ProcessStatusOS[MAX_TASKS];
OurTaskStatus_t *ProcessStatus;
uint32_t task_idx, row_idx, col_idx;
char buf[32];
ProcessStatus = shmem_p->cpud[cpu_id].ProcessStatus;
if( cpu_id == 0 ) {
shmem_p->cpud[cpu_id].task_cnt = uxTaskGetNumberOfTasks();
uxTaskGetSystemState( ProcessStatusOS, shmem_p->cpud[cpu_id].task_cnt, NULL ); // Only get info if local CPU!
for( int i = 0; i < shmem_p->cpud[cpu_id].task_cnt; i++ ) {
strcpy( (ProcessStatus+i)->pcTaskName, ProcessStatusOS[i].pcTaskName );
(ProcessStatus+i)->eCurrentState = ProcessStatusOS[i].eCurrentState;
(ProcessStatus+i)->uxCurrentPriority = ProcessStatusOS[i].uxCurrentPriority;
(ProcessStatus+i)->usStackHighWaterMark = ProcessStatusOS[i].usStackHighWaterMark;
qsort( ProcessStatus, shmem_p->cpud[cpu_id].task_cnt, sizeof(OurTaskStatus_t), (void*)compare_proc_name ); // Sort Alphabetically by name
lv_table_set_row_cnt(tsk_table, shmem_p->cpud[cpu_id].task_cnt + 1);
for( row_idx = 0; row_idx < (shmem_p->cpud[cpu_id].task_cnt + 1); row_idx++ ) {
for( col_idx = 0; col_idx < NUM_COLUMNS; col_idx++ ) lv_table_set_cell_type(tsk_table, row_idx, col_idx, 2);
lv_table_set_cell_value( tsk_table, 0, 0, "Task" );
lv_table_set_cell_value( tsk_table, 0, 1, "Priority" );
lv_table_set_cell_value( tsk_table, 0, 2, "State" );
lv_table_set_cell_value( tsk_table, 0, 3, "Lowest Stack" );
for( task_idx = 0; task_idx < shmem_p->cpud[cpu_id].task_cnt; task_idx++ ) {
row_idx = task_idx+1;
lv_table_set_cell_value(tsk_table, row_idx, 0, (ProcessStatus[task_idx].pcTaskName));
sprintf(buf, "%lu", ProcessStatus[task_idx].uxCurrentPriority);
lv_table_set_cell_value(tsk_table, row_idx, 1, buf);
switch (ProcessStatus[task_idx].eCurrentState) {
case eReady:
lv_table_set_cell_value(tsk_table, row_idx, 2, "Ready");
break;
case eBlocked:
lv_table_set_cell_value(tsk_table, row_idx, 2, "Blocked");
break;
case eDeleted:
lv_table_set_cell_value(tsk_table, row_idx, 2, "Deleted");
break;
case eSuspended:
lv_table_set_cell_value(tsk_table, row_idx, 2, "Suspended");
break;
case eRunning:
lv_table_set_cell_value(tsk_table, row_idx, 2, "Running");
break;
default:
lv_table_set_cell_value(tsk_table, row_idx, 2, "Unknown");
break;
sprintf(buf, "%d", (ProcessStatus[task_idx].usStackHighWaterMark * 4));
lv_table_set_cell_value(tsk_table, row_idx, 3, buf);
static void* update_task_list( void ) {
char s_buf[80];
sprintf( s_buf, "CPU0 Task List:(%lu items)",shmem_p->cpud[0].task_cnt );
lv_label_set_text(cpu0_label, s_buf);
update_task_tables( 0, tsk_table0 ); // Update CPU 0 Task table
sprintf( s_buf, "CPU1 Task List:(%lu items)",shmem_p->cpud[1].task_cnt );
lv_label_set_text(cpu1_label, s_buf);
update_task_tables( 1, tsk_table1 ); // Update CPU 1 Task table
return( NULL );
void sysinfo_create( lv_obj_t * parent ) {
uint32_t col_idx;
static lv_obj_t *page1, *page2;
cpu0_label = lv_label_create(parent, NULL);
cpu1_label = lv_label_create(parent, NULL);
lv_obj_set_pos(cpu0_label, 96, 10);
lv_obj_set_style_local_text_font (cpu0_label, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, &lv_font_roboto_bi16);
lv_obj_set_pos(cpu1_label, 96, (lv_obj_get_height_fit( parent ) / 2)+10);
lv_obj_set_style_local_text_font (cpu1_label, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, &lv_font_roboto_bi16);
page1 = lv_page_create( parent, NULL );
lv_obj_set_size( page1, 800, ((lv_obj_get_height_fit( parent ) / 2)-45) );
lv_obj_set_pos( page1, 96, 35 );
setup_scrl_bar( page1, LV_PAGE_PART_SCROLLBAR, 8);
lv_page_set_scrollbar_mode(page1, LV_SCROLLBAR_MODE_AUTO);
tsk_table0 = lv_table_create(page1, NULL);
lv_obj_set_drag_parent(tsk_table0, pdTRUE);
lv_obj_set_style_local_text_font (tsk_table0, LV_TABLE_PART_CELL2, LV_STATE_DEFAULT, &lv_font_roboto_12);
lv_obj_set_pos(tsk_table0, 0, 0 );
lv_table_set_col_cnt(tsk_table0, NUM_COLUMNS);
lv_table_set_row_cnt(tsk_table0, 1);
for( col_idx = 0; col_idx < NUM_COLUMNS; col_idx++ ) {
lv_table_set_cell_type(tsk_table0, 0, col_idx, 2);
lv_table_set_col_width(tsk_table0, col_idx, 150);
page2 = lv_page_create( parent, NULL );
lv_obj_set_size( page2, 800, ((lv_obj_get_height_fit( parent ) / 2)-45) );
lv_obj_set_pos( page2, 96, (lv_obj_get_height_fit( parent ) / 2)+35 );
setup_scrl_bar( page2, LV_PAGE_PART_SCROLLBAR, 8);
lv_page_set_scrollbar_mode(page2, LV_SCROLLBAR_MODE_AUTO);
tsk_table1 = lv_table_create(page2, NULL);
lv_obj_set_drag_parent(tsk_table1, pdTRUE);
lv_obj_set_style_local_text_font (tsk_table1, LV_TABLE_PART_CELL2, LV_STATE_DEFAULT, &lv_font_roboto_12);
lv_obj_set_pos( tsk_table1, 0, 0 );
lv_table_set_col_cnt(tsk_table1, NUM_COLUMNS);
lv_table_set_row_cnt(tsk_table1, 1);
lv_table_set_cell_type(tsk_table1, 0, col_idx, 2);
lv_table_set_col_width(tsk_table1, col_idx, 150);
update_task_list();
lv_task_create((void*)update_task_list, 2001, LV_TASK_PRIO_LOWEST, NULL ); // Update the process table every 2 seconds
Hope that helps.
Kind Regards,
Pete
