I would like to add large amount of options to a ROLLER widget ( above 3000 items)
I have something like this in my program memory:
const char *options[] PROGMEM={
"Opt1",
"Opt2",
"This option field is very long",
"Opt4",
"Opt5",
"Opt3000"
So is it possible to add this to a Roller? And how?
Also, when the text in highlighted option is larger than roller width, is it possible to auto scroll ?
Hi @skartalov ,
I assume you are using version 8 of lvgl…
Sorry but currently there is no way of assigning an external data array to the Roller Widget.
However if you can use a drop down instead it does have this functionality see docs here.
Also if you are adding many items you will probably need to set this in your lv_conf.h file:
/*Extend the default -32k..32k coordinate range to -4M..4M by using int32_t for coordinates instead of int16_t*/
#define LV_USE_LARGE_COORD 1
Hope that helps…
Kind Regards,
Pete
Yes, version 8.
I would like to scroll these options like scrolling a phonebook on a mobile phone.
Drop Down is not the same experience.
Hope in the future versions they will add such an option for Roller…
Thanks!
