How to add Knob to arc and set value from 0 to 100
Hi Team,
i have few questions
  1. is it possible to add knob to arc?
  2. is it possible to set arc values from 0 to 100?
    Please give an example
ARM
v6
i want to set the arc value from 0 to 100 using knob. i want to use this arc instead of slider
Nothing
Yes. Arc (lv_arc) — LVGL documentation
Yes. lv_arc_set_range(arc, 0, 100)
i am using lvgl version 6 is it possible in it?
No; this was only added to version 7.
Ok. How to convert lvgl version 6 to version 7
You would need to download the new version from GitHub. However, do be aware the style system has changed and you will need to rewrite any custom styles you may currently be using. My style compatibility module may be helpful.
OK i will change to version 7. Thanks for your help
