HOW TO ADD DIFFERENT COLOR BASED ON THE Y VALUE FOR A SAME SERIES IN A CHART WIDGET [CHART TYPE : COLOUMN]
ESP32 WROOVER IE
LVGL v7.11.0
I WANT OUTPUT IN WHICH I WILL GET A COLOR CHANGE BASED ON Y VALUE OF CHART FOR A SAME SERIES
I AM ABLE TO ACHIVE DIFFERENT COLORS FOR DIFFERENTSERIES BUT IF I AM ADDING SERIES MY COLOUM WIDTH IS DECREASING
void lv_chart(void)
/*Create a chart*/
lv_point_t point = {10, 20};
lv_obj_t * scr1 = lv_obj_create(NULL, NULL);
chart = lv_chart_create(scr1, NULL);
lv_obj_set_size(chart, 200, 150);
lv_obj_align(chart, NULL, LV_ALIGN_CENTER, 15, 0);
lv_chart_set_type(chart, LV_CHART_TYPE_COLUMN ); /*Show lines and points too*/
/*Add a faded are effect*/
lv_obj_set_style_local_bg_opa(chart, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, LV_OPA_50); /*Max. opa.*/
lv_obj_set_style_local_bg_grad_dir(chart, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, LV_GRAD_DIR_VER);
lv_obj_set_style_local_bg_main_stop(chart, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, 255); /*Max opa on the top*/
lv_obj_set_style_local_bg_grad_stop(chart, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, 0); /*Transparent on the bottom*/
/*Add two data series*/
ser1 = lv_chart_add_series(chart, lv_color_hex(0x25cc1a));
ser2 = lv_chart_add_series(chart, lv_color_hex(0xffd963));
ser3 = lv_chart_add_series(chart, lv_color_hex(0xff6262));
lv_chart_cursor_t * c1 = lv_chart_add_cursor(chart, lv_color_hex(0xffd963), LV_CHART_CURSOR_LEFT);
lv_chart_set_cursor_point(chart, c1, &point);
// lv_chart_set_range(chart, 0, 800);
lv_chart_set_div_line_count(chart, 0, 0);
lv_chart_set_x_tick_length(chart,100,10);
lv_chart_set_next(chart, ser1, I);
lv_scr_load(scr1);
