How to achieve alpha masking with antialias?
I wonder if there is a way to achieve alpha masking with antialias.
The effect I expect is like this
It should be possible in dev-7.0 with the new masking system, but there is no documentation written yet, as it’s still a pre-release. :slightly_frowning_face:
I now know that alpha masking can be implemented with canvas (LV_IMG_CF_TRUE_COLOR_CHROMA_KEYED, LV_COLOR_TRANSP), but this has not been applied with anti-aliasing, so I wonder if there is a way to achieve anti-aliasing.
You don’t need to do it with a canvas; as I understand it 7.0 has the ability to punch holes in normal objects (antialiasing included).
That’s great, how can I achieve this, objmask, any examples?
@kisvegabor
@embeddedt
Hi, I have achieved this now, the primary code like this
lv_obj_t *objmask = lv_objmask_create(lv_scr_act(), NULL);
lv_draw_mask_radius_init(…);
lv_objmask_add_mask(…);
lv_obj_t *obj = lv_obj_create(objmask, NULL);
Best regards.
Exactly! :slight_smile:
You can make experiment with the other mask types too.
This mechanisms are working under the hood in new drawing system of dev-7.0 which quite new, so every feedback is highly appreciated!
Okay, very good.
If I want to achieve triangle or polygon alpha masking, then I can apply which mask type.
In trivial cases, you can create them from lines.
For more complicated cases you can draw to an LV_IMG_CF_ALPHA_8BIT canvas and create a map mask from it. Black colors will be masked out, white parts will be kept.
Do this such as lv_line_create(…) or lv_draw_mask_line_param_t…?
YES, I can now create more possibilities with this method.
I meant lv_draw_mask_line_param_t.
Okay.
It would be better if there is such an example.
We’re planning to write some documentation for the new features, but as v7.0 is still under development we haven’t started yet.
Very good!
