How to access alpha array in display flush callback RGB565A8?
How is the alpha array included in the RGB565A8 color format accessed using the px_map pointer? It seems like the buffers provided to display set buffers would be structured like two arrays in contiguous memory: arrayRGB[HOR * VER * 2Bytes] + arrayAlpha[HOR * VER * 1Byte]. However when I look at the data in the last 3rd of the memory allotted to my buffers the value is always 0. I have color depth set to 16 and I have enabled all color formats for draw sw support, just in case.
RISCV
9.2
Access RGB565A8 alpha mask/buffer/array for overlaying graphics on a input video stream.
Using the same codebase to run in ARGB8888 using the windows simulator seeing expected values in the alpha byte.
Running on hardware using ARGB888 color format, display will not run in this format, but the alpha bytes appear as expected.
Running on hardware using RGB565 color format, graphics appear as expected, but have no transparency.
I tried memsetting the last 3rd of the display buffers to 0x7F to check if 0 was the calculated alpha value, however the 0x7F values were not overwritten and remained indefinitely even as the first 2/3s of the buffer was updated with new RGB565 values.
    lv_display_t * disp = lv_display_create(MY_DISP_HOR_RES, MY_DISP_VER_RES);
    lv_display_set_color_format(disp, LV_COLOR_FORMAT_RGB565A8);
    lv_display_set_flush_cb(disp, disp_flush);
    static uint8_t buf_3_1[MY_DISP_HOR_RES * MY_DISP_VER_RES * BYTE_PER_PIXEL];
    static uint8_t buf_3_2[MY_DISP_HOR_RES * MY_DISP_VER_RES * BYTE_PER_PIXEL];
    lv_display_set_buffers(disp, buf_3_1, buf_3_2, sizeof(buf_3_1), LV_DISPLAY_RENDER_MODE_DIRECT);
static void disp_flush(lv_display_t * disp_drv, const lv_area_t * area, uint8_t * px_map)
    setRGBData(px_map);
    setAlphaData(px_map + MY_DISP_HOR_RES * MY_DISP_VER_RES * BYTE_PER_PIXEL-1);
    /*IMPORTANT!!!
     *Inform the graphics library that you are ready with the flushing*/
    lv_display_flush_ready(disp_drv);
