F1C100S
V8.3.6
When I click switch then pop up MessageBox, MessageBox display Chinese, choose 确定 or 取消, so switch turn on or turn off.(“确定” in English is sure, “取消” in English is cancle.)
See lvgl official sample and try to modify it, I think in MessageBox for 确定 or 取消 need set font, but I not see like this sample. I run below code that I provide, result is I see box in 确定 and 取消 position.
static void event_cb(lv_event_t* e)
lv_obj_t* obj = lv_event_get_current_target(e);
LV_LOG_USER("Button %s clicked", lv_msgbox_get_active_btn_text(obj));
void lv_example_msgbox_1(void)
//static const char* btns[] = { "Apply", "Close", "" };
static const char* btns[] = { "确定", "取消", "" };
//lv_obj_t* mbox1 = lv_msgbox_create(NULL, "Hello", "This is a message box with two buttons.", btns, true);
lv_obj_t* mbox1 = lv_msgbox_create(NULL, NULL, "This is a message box with two buttons.", btns, true);
lv_obj_add_event_cb(mbox1, event_cb, LV_EVENT_VALUE_CHANGED, NULL);
lv_obj_center(mbox1);
static void event_handler(lv_event_t* e)
if (code == LV_EVENT_VALUE_CHANGED) {
LV_UNUSED(obj);
lv_example_msgbox_1();
Call function is below:
ui_Switch1 = lv_switch_create(ui_Screen1);
lv_obj_set_width(ui_Switch1, 100);
lv_obj_set_height(ui_Switch1, 42);
lv_obj_set_x(ui_Switch1, -329);
lv_obj_set_y(ui_Switch1, -192);
lv_obj_set_align(ui_Switch1, LV_ALIGN_CENTER);
lv_obj_add_event_cb(ui_Switch1, event_handler, LV_EVENT_ALL, NULL);
