Hi! I’m setting up a wifi connect screen. The starting state has all items hidden-flag set true except a “scan” button. The callback for the scan button, in essence, should:
- Unflag hidden from a spinner widget
- Starts an async
WiFi.scanNetworks
call
2a) on finding networks, unhides a roller widget and a select button, and hides the spinner
2b) on finding no networks, hides the spinner and displays a no networks found message
And so on through the wifi connection process - brings up a keyboard when a network is selected, hides the select button, shows a connect and cancel button that go on to revert or progress the process.
However, upon pressing the initial scan button, the UI appears to lock until all of the work inside the callback is finished. The button clearly renders in the “pressed” state until the full network scan is over, during which times there should have been a few ui updates.
A simple way to reproduce is below.
lilygo t-display s3 (esp32s3) using platformio
8.3.11
I am unsure of the correct pattern to achieve the level of responsiveness I’m looking for. I have considering registering a bunch of tasks and having the different buttons trigger tasks and subtasks but that would be incredibly awkward.
Here is a much simplified example
void scanWifiEventHandler(lv_event_t * e) {
Serial.println("wifi scan start");
// I expect this to happen before the delay begins
lv_obj_clear_flag(ui_wifiSpinner, LV_OBJ_FLAG_HIDDEN);
// Nothing happens until the delay ends
delay(1000);
Here is a more comprehensive look at the actual code for anyone interested:
Serial.println("Wifi scan wating on semaphore");
if ( xSemaphoreTake( xWiFiLock, portMAX_DELAY ) == pdTRUE ) {
int16_t wifi_scan_status;
ui_set_no_networks();
ui_set_on_visibility(ui_wifiSpinner);
// async scan to not block watchdog
WiFi.disconnect();
delay(250);
Serial.println("wifi disconnected");
WiFi.scanNetworks(true);
// wait for wifi scan result
Serial.println("waiting for result");
while(1) {
delay(250);
wifi_scan_status = WiFi.scanComplete();
if (wifi_scan_status == WIFI_SCAN_FAILED) {
Serial.println("WIFI SCAN FAILED!");
break;
} else if (wifi_scan_status == WIFI_SCAN_RUNNING){
Serial.println("Continuing to search");
continue;
} else {
Serial.println("status check:");
Serial.println(wifi_scan_status);
break;
Serial.println("wifi scan result count:");
if (wifi_scan_status > 0) {
ui_set_found_networks();
ui_roller_show_results(wifi_scan_status);
ui_set_off_visibility(ui_wifiSpinner);
xSemaphoreGive( xWiFiLock );
