* @file demo.c
* INCLUDES
#include "demo.h"
#include "string.h"
#if LV_USE_DEMO
* DEFINES
* TYPEDEFS
* STATIC PROTOTYPES
void demo_create(void);
static lv_obj_t * selected;
static void list_btn_event_handler_selected(lv_obj_t * , lv_event_t event);
#if LV_DEMO_SLIDE_SHOW
static void tab_switcher(lv_task_t * task);
* STATIC VARIABLES
static lv_obj_t * chart;
static lv_obj_t * ta;
static lv_obj_t * kb;
static lv_style_t style_kb;
static lv_style_t style_kb_rel;
static lv_style_t style_kb_pr;
#if LV_DEMO_WALLPAPER
LV_IMG_DECLARE(img_bubble_pattern)
LV_IMG_DECLARE(test_icon1);
#define LV_COLOR_DARK_YELLOW LV_COLOR_MAKE(0xca, 0xca, 0x12)
#define LV_COLOR_ORANGE LV_COLOR_MAKE(0xff, 0x66, 0x00)
#define LV_COLOR_GREEN LV_COLOR_MAKE(0x3c, 0xac, 0x47)
#define LV_COLOR_BLUE LV_COLOR_MAKE(0x30, 0x33, 0xff)
#define LV_COLOR_DARK_BLUE LV_COLOR_MAKE(0x00, 0x54, 0x85)
#define LV_COLOR_DEEPSKYBLUE LV_COLOR_MAKE(0xe8, 0xe7, 0xe6)
#define LV_COLOR_BUTTON_PR_GRAY LV_COLOR_MAKE(0xc4, 0xc4, 0xc4)
#define LV_COLOR_GRAY LV_COLOR_MAKE(0xc0, 0xc0, 0xc0)
#define LV_COLOR_DARK_GRAY LV_COLOR_MAKE(0x5a, 0x5a, 0x5a)
#define LV_COLOR_DARK_MEDIUMSEAGREEN LV_COLOR_MAKE(0x3c, 0xB3, 0x71)
#define LV_COLOR_TOMATO LV_COLOR_MAKE(0xFF, 0x63, 0x47)
#define LV_COLOR_DEEPSKYBLUE LV_COLOR_MAKE(0x00, 0xBF, 0xFF)
#define LV_COLOR_DEEPDARKGRAY LV_COLOR_MAKE(0x38, 0x38, 0x38)
* MACROS
* GLOBAL FUNCTIONS
* Create a demo application
lv_coord_t hres = lv_disp_get_hor_res(NULL);
lv_coord_t vres = lv_disp_get_ver_res(NULL);
//set style
static lv_style_t style_screen;
lv_style_copy(&style_screen, &lv_style_plain);
style_screen.body.main_color = LV_COLOR_DARK_YELLOW;
style_screen.body.grad_color = LV_COLOR_DARK_GRAY ;
lv_obj_set_style(lv_scr_act(), &style_screen);
//set header
static lv_style_t style_status_bar_bg;
lv_style_copy(&style_status_bar_bg, &lv_style_plain);
style_status_bar_bg.body.main_color = LV_COLOR_DARK_YELLOW;
style_status_bar_bg.body.grad_color = LV_COLOR_DARK_YELLOW;
style_status_bar_bg.body.padding.top = 0;
style_status_bar_bg.body.padding.bottom = 0;
style_status_bar_bg.body.opa = 0.3;
style_status_bar_bg.text.color = LV_COLOR_WHITE;
lv_obj_t * header;
header = lv_obj_create(lv_scr_act(), NULL);
lv_obj_set_size(header, hres, 80);
lv_obj_set_style(header, &style_status_bar_bg);
lv_obj_align(header, NULL, LV_ALIGN_IN_TOP_MID,0,0);
lv_obj_t * status_bar = lv_obj_create(header, NULL);
lv_obj_set_width(status_bar, lv_disp_get_hor_res(NULL));
lv_obj_set_pos(status_bar, 0, 5);
lv_obj_set_style(status_bar, &style_status_bar_bg);
lv_obj_t * sym = lv_label_create(status_bar, NULL);
lv_label_set_text(sym, LV_SYMBOL_WIFI LV_SYMBOL_BATTERY_FULL);//LV_SYMBOL_LIST
lv_obj_align(sym, NULL, LV_ALIGN_IN_TOP_RIGHT, -LV_DPI/10, 0);
lv_obj_t * clock = lv_label_create(status_bar, NULL);
lv_label_set_text(clock, "09:07");
lv_obj_align(clock, NULL, LV_ALIGN_IN_TOP_LEFT, LV_DPI/10, 0);
// second line
static lv_style_t style_status_sec_bar_bg;
lv_style_copy(&style_status_sec_bar_bg, &style_status_bar_bg);
style_status_sec_bar_bg.text.font = &lv_font_roboto_22;
//BODY BEGIN
lv_style_t *sb = lv_page_create(lv_disp_get_scr_act(NULL), NULL);
lv_page_set_sb_mode(sb, LV_SB_MODE_OFF);
lv_page_set_style(sb, LV_PAGE_STYLE_BG, &lv_style_transp_tight);
lv_page_set_style(sb, LV_PAGE_STYLE_SCRL, &lv_style_transp);
lv_obj_t * cont;
//Icons
//Fonts
lv_font_t *font_roboto_28 = &lv_font_roboto_28;
lv_font_t *font_roboto_22 = &lv_font_roboto_22;
lv_font_t *font_roboto_16 = &lv_font_roboto_16;
lv_font_t *font_roboto_12 = &lv_font_roboto_12;
//Colors
lv_color_t *white = &LV_COLOR_WHITE;
lv_color_t *deepsky = &LV_COLOR_DEEPSKYBLUE;
selected1();
if(hres > vres) { // size of page
lv_obj_set_height(sb, vres - lv_obj_get_height(header));
lv_cont_set_fit2(sb, LV_FIT_TIGHT, LV_FIT_NONE);
lv_obj_align(sb, header, LV_ALIGN_OUT_BOTTOM_LEFT, 0, 0);
} else {
lv_obj_set_size(sb, hres, vres - lv_obj_get_height(header));
lv_task_create(tab_switcher, 3000, LV_TASK_PRIO_MID, tv);
* STATIC FUNCTIONS
void selected1(void){
selected = lv_obj_create(NULL, NULL);
lv_scr_load(selected);
//set header
lv_obj_t * header;
const void *var_arrow_up = &arrow_up;
const void *var_arrow_down = &arrow_down;
const void *var_procent = &procent;
const void *var_done = &done;
const void *var_target = ⌖
const void *var_effect = &effective;
const void *var_hum = &Humidity;
const void *var_temp = &Temperature;
const void *var_pres = &Presure;
const void *var_unlock = &Unlock;
const void *var_date = &Date;
const void *var_batt = &Battery;
const void *var_risk = &Risk;
const void *var_flash = &Flash;
const void *var_filter = &Filter;
const void *var_ant = &Antenna;
const void *var_ble = &Bleutooth;
const void *var_wrench = &Wrench;
const void *var_report = &Report;
const void *var_ok = &Ok;
const void *var_vol = &vol;
const void *var_led = &led;
const void *var_wifi = &wifi;
const void *var_contrast = &contrast;
const void *var_language = &language;
const void *var_luminosity = &luminosity;
const void *var_sleep_timer = &sleep_timer;
const void *var_search = &search;
const void *var_arrow_left = &arrow_left;
const void *var_arrow_right = &arrow_right;
const void *var_download = &download;
// second line
lv_obj_t * icon = lv_img_create(lv_scr_act(), NULL);
//Fonts
//Colors
// lv_img_set_src(icon2, &archive);
// lv_obj_align(icon2, status_bar, LV_ALIGN_IN_TOP_RIGHT,-10,30);
// lv_img_set_src(icon, &test_icon1);
// lv_obj_align(icon, status_bar, LV_ALIGN_IN_BOTTOM_RIGHT,-10, -5);
//END of HEADER
//BODY BEGIN
// lv_page_set_scrl_layout(sb, LV_LAYOUT_PRETTY);
label_create(header,"Hidden Menu",100,50,font_roboto_22, LV_COLOR_WHITE);
buttons_create_selected(style_status_bar_bg, selected, "TEST",30,140,5);
} else {
void img_button_create(lv_style_t style_status_sec_bar_bg,lv_obj_t * cont, const void *var_icon, int* x_pos, int * y_pos )
lv_obj_t * btn1 = lv_btn_create(cont, NULL);
// lv_obj_set_event_cb(btn1, event_handler);
// lv_btn_set_fit(btn1,LV_FIT_TIGHT);
lv_obj_set_size(btn1,60,55);
// lv_obj_align(btn1, NULL, LV_ALIGN_IN_BOTTOM_MID, x_pos, y_pos);
lv_obj_set_pos(btn1, x_pos,y_pos);
lv_obj_t *icon = lv_img_create(btn1, NULL);
// lv_table_set_style(icon1, L_STYLE_BG,&lv_style_transp_tight);
lv_img_set_src(icon,var_icon);
lv_obj_set_pos(icon, 0,0);
void buttons_create_selected(lv_style_t style_status_sec_bar_bg,lv_obj_t * sb, char * name, int* x_pos, int * y_pos, int* rad )
lv_obj_t * btn_label;
lv_obj_t * btn1 = lv_btn_create(sb, NULL);
static lv_style_t style_btn_bg;
static lv_style_t style_btn_pr_bg;
lv_style_copy(&style_btn_bg, &style_status_sec_bar_bg);
style_btn_bg.body.main_color = LV_COLOR_DARK_YELLOW;
style_btn_bg.body.grad_color = LV_COLOR_DARK_YELLOW;
style_btn_bg.text.color = LV_COLOR_WHITE;
style_btn_bg.text.font = &lv_font_roboto_16;
style_btn_bg.body.opa = 255;
style_btn_bg.body.radius = rad;
lv_style_copy(&style_btn_pr_bg, &style_btn_bg);
style_btn_pr_bg.body.main_color = LV_COLOR_BUTTON_PR_GRAY;
style_btn_pr_bg.body.grad_color = LV_COLOR_BUTTON_PR_GRAY;
lv_btn_set_style(btn1,LV_BTN_STYLE_REL, &style_btn_bg);
lv_btn_set_style(btn1,LV_BTN_STYLE_PR, &style_btn_pr_bg);
lv_obj_set_event_cb(btn1, list_btn_event_handler_selected);
lv_obj_set_size(btn1, 120, 40);
// lv_obj_align(btn1, NULL, LV_ALIGN_IN_TOP_MID, x_pos, y_pos);
btn_label = lv_label_create(btn1, NULL);
lv_label_set_text(btn_label, name);
// lv_obj_set_auto_realign(btn_label,true);
lv_obj_set_auto_realign(btn_label, true);
lv_obj_align(btn_label, NULL, LV_ALIGN_IN_TOP_MID, 0, 0);
lv_label_set_align(btn_label, LV_LABEL_ALIGN_CENTER);
void label_create(lv_obj_t * cont,char *title, int *x_pos,int *y_pos, const lv_font_t *font_lb, lv_color_t color)
lv_style_t *style_lb = malloc(sizeof(lv_style_t));
lv_obj_t * label1 = lv_label_create(cont, NULL);
lv_label_set_text(label1, title);
lv_style_copy(style_lb, &lv_style_plain);
style_lb->text.color = color;
style_lb->text.font = font_lb;
lv_label_set_style(label1, LV_LABEL_STYLE_MAIN, style_lb);
lv_obj_set_pos(label1, x_pos,y_pos);
static void list_btn_event_handler_selected(lv_obj_t * btn, lv_event_t event)
if (event == LV_EVENT_CLICKED) {
switch(lv_btn_get_state(btn)) {
case LV_BTN_STYLE_REL:
case LV_BTN_STYLE_PR:
printf("first ");
break;
case LV_BTN_STYLE_TGL_REL:
case LV_BTN_STYLE_TGL_PR:
printf("second ");
lv_obj_del(icon);
break;
default:
break;
* Called periodically (lv_task) to switch to the next tab
static uint8_t tab = 0;
lv_obj_t * tv = task->user_data;
tab++;
if(tab >= 3) tab = 0;
lv_tabview_set_tab_act(tv, tab, true);
#endif /*LV_USE_DEMO*/
