How does an online image converter convert RGB888 to RGB565?
I want to write a tool for converting png to LV_IMG_CF_TRUE_COLOR_ALPHA ,like an online converter.
First I read every pixel of the picture, and then I converted those pixels to TRUE_COLOR_ALPHA format. I compare my tools to the results of online conversions, and they are not the same.
For example, RGB(88, 33, 44), the online tool’s conversion result is: 0x06, 0x59, and my tool’s conversion result is: 0x5, 0x59.
x86
lvgl8.3
I just want to know, how does the online converter convert rgb888 to rgb565?
Here is my conversion code
        static UInt16 BRGA2RGB565(byte b, byte g, byte r, byte a = 0xFF)
            int ir = r >> 3;
            int ig = g >> 2;
            int ib = b >> 3;
            int v = ib;
            v |= ig << 5;
            v |= ir << 11;
            return (UInt16)v;
Hi @LuAn ,
LVGL’s converters and internals use the standard “truncate and pack” formula for RGB888 → RGB565, but note the channel order and that they work in BGR order in several places.
    int ir = r >> 3;   // 5 bits
    int ig = g >> 2;   // 6 bits
    int ib = b >> 3;   // 5 bits
    int v = ib;
    v |= ig << 5;
    v |= ir << 11;
    return (UInt16)v;
this matches the LVGL packing formula (B,G,R → RGB565). The 1‑bit difference you see (0x06 vs 0x05 in the high byte) is not explained by any alternative rounding in the LVGL sources: they always use simple shifts and masks, no rounding up
