Hello, we have a 128x64 pixel OLED display, the first 16 pixel rows are yellow, and the rest are blue. Note that the colors are not controlled in software, they are physically yellow or blue according to position.
The top 16 pixel rows are intend as a yellow status bar, and the rest are blue for general application use.
ESP32-C6
8.3
We are trying to make LVGL provide a status bar at the top in yellow, with a menu below that which is as compact as possible.
We tried to use a grid with 1 column and 2 rows, where the first row is 16 pixels high, and the second row is the remainder of the screen. We then put a label in grid 0,0 and a menu in grid 1,0. Even though we have set the grid to these constraints, it is not placing the text properly: the status bar is below the 16-pixel row, and there appears to be padding around each grid even though we set the borders to 0.
I just hacked this into main.c in lv_port_pc_eclipse and it builds and shows the same problem we are having on the ESP32. This snippet replaces the main() function in main.c:
void menu_item(lv_group_t *group, lv_obj_t *main_page, lv_style_t *style, char *item_name)
lv_obj_t *cont;
lv_obj_t *label;
cont = lv_menu_cont_create(main_page);
lv_obj_add_style(cont, style, LV_STATE_FOCUS_KEY);
lv_group_add_obj(group, cont);
lv_obj_clear_flag(cont, LV_OBJ_FLAG_SCROLLABLE);
lv_obj_add_flag(cont, LV_OBJ_FLAG_SCROLL_ON_FOCUS);
label = lv_label_create(cont);
lv_label_set_text(label, item_name);
void lvgl_menu()
// Lock the mutex due to the LVGL APIs are not thread-safe
//if (lvgl_port_lock(0))
lv_obj_t *scr = lv_disp_get_scr_act(NULL);
lv_obj_set_size(scr, lv_disp_get_hor_res(NULL), lv_disp_get_ver_res(NULL));
lv_group_t *group = lv_group_get_default();
//lv_group_set_default(group);
//lv_indev_set_group(indev_keypad, group);
static lv_style_t style;
lv_style_init(&style);
lv_style_set_bg_color(&style, lv_color_hex(0x000000));
lv_style_set_border_width(&style, 0);
lv_style_set_border_color(&style, lv_color_hex(0xff0000));
static lv_style_t no_border;
lv_style_init(&no_border);
lv_style_set_border_width(&no_border, 0);
lv_obj_add_style(scr, &no_border, LV_STATE_DEFAULT);
static lv_coord_t col[] = {LV_GRID_FR(1), LV_GRID_TEMPLATE_LAST};
static lv_coord_t row[] = {16, LV_GRID_FR(1), LV_GRID_TEMPLATE_LAST};
lv_obj_t *grid = lv_obj_create(scr);
lv_obj_add_style(grid, &no_border, LV_STATE_DEFAULT);
lv_obj_set_size(grid, lv_disp_get_hor_res(NULL), lv_disp_get_ver_res(NULL));
lv_obj_center(grid);
lv_obj_set_grid_dsc_array(grid, col, row);
lv_obj_t *status_bar_label = lv_label_create(grid);
lv_label_set_text(status_bar_label, "bar");
lv_obj_center(status_bar_label);
lv_obj_add_style(status_bar_label, &no_border, LV_STATE_DEFAULT);
lv_obj_set_grid_cell(status_bar_label, LV_GRID_ALIGN_STRETCH, 0, 1,
LV_GRID_ALIGN_STRETCH, 0, 1);
lv_obj_t *menu = lv_menu_create(grid);
lv_obj_set_grid_cell(menu, LV_GRID_ALIGN_STRETCH, 0, 1,
LV_GRID_ALIGN_STRETCH, 1, 1);
lv_obj_add_style(menu, &no_border, LV_STATE_DEFAULT);
lv_obj_center(menu);
// Create a main page
lv_obj_t *main_page = lv_menu_page_create(menu, NULL);
menu_item(group, main_page, &style, "zeke 1 2 3");
lv_menu_set_page(menu, main_page);
// Release the mutex
//lvgl_port_unlock();
int main(int argc, char **argv)
/*Initialize LVGL*/
/*Initialize the display, and the input devices*/
hal_init(128, 64);
lvgl_menu();
/*To hide the memory and performance indicators in the corners
*disable `LV_USE_MEM_MONITOR` and `LV_USE_PERF_MONITOR` in `lv_conf.h`*/
while(1) {
/* Periodically call the lv_task handler.
* It could be done in a timer interrupt or an OS task too.*/
lv_timer_handler();
usleep(10* 1000);
demo_end:
lv_deinit();
return 0;
This is what it looks like with the grid. The text “bar” should be all yellow, we will use it for static symbols (signal strength, etc):
If we remove the grid and only place the menu then it fills the screen, but the menuitem rows are very large even though we set border_width to 0. We would like to achive about 3 menu rows in the remaining 48 pixel rows below yellow section:
