How do you set the height of row 1 in a table?
I have a table where I want to set a header row in a different larger font size. However as the main table has font size 18 the first row (using font size 24) is too short.
Linux/SDL and Arduino
8.3.4
I would like to change the header row to show the text without being chopped off.
Setting the font of the table to 24 then overriding the rows > 0 to use font 18 but that causes other weird behavior including wrapping where not applicable.
void create_tabCalendar(lv_obj_t * parent)
    calendartable = lv_table_create(parent);
    //8.1 to fix
	//lv_obj_set_drag_parent(calendartable, true);
    lv_obj_set_style_radius(calendartable, 10, 0);
    lv_obj_set_style_clip_corner(calendartable, true, 0);
    lv_obj_set_pos(calendartable, 40, -13);
    //lv_obj_set_style_pad_bottom(calendartable, -5, LV_PART_MAIN);
    lv_obj_set_style_pad_bottom(parent, 5, LV_PART_MAIN);
    //lv_obj_clear_flag( parent, LV_OBJ_FLAG_SCROLLABLE );
    lv_obj_set_style_border_color(calendartable, MAIN_BORDER_COLOUR, LV_PART_MAIN);
    lv_obj_set_style_border_color(calendartable, MAIN_BORDER_COLOUR, LV_PART_ITEMS);
    lv_obj_set_style_pad_top(calendartable, 5, LV_PART_ITEMS);
    lv_obj_set_style_pad_bottom(calendartable, 5, LV_PART_ITEMS);
    lv_obj_set_style_pad_left(calendartable, 10, LV_PART_ITEMS);
    lv_obj_set_style_pad_right(calendartable, 2, LV_PART_ITEMS);
    lv_table_set_col_cnt(calendartable, 4);
    lv_table_set_row_cnt(calendartable, calendarRows+1);
    lv_table_set_col_width(calendartable, 0, 260);
    lv_table_set_col_width(calendartable, 1, 340);
    lv_table_set_col_width(calendartable, 2, 150);
    lv_table_set_col_width(calendartable, 3, 150);
    lv_obj_set_style_text_font(calendartable, &lv_font_montserrat_18, 0);
    lv_table_set_cell_value(calendartable, 0, 0, "Calendar");
    lv_table_set_cell_value(calendartable, 0, 1, "Summary");
    lv_table_set_cell_value(calendartable, 0, 2, "Start");
    lv_table_set_cell_value(calendartable, 0, 3, "End");
    lv_obj_add_event_cb(calendartable, draw_part_calendar_event_cb, LV_EVENT_DRAW_PART_BEGIN, NULL);
static void draw_part_calendar_event_cb(lv_event_t * e)
    lv_obj_draw_part_dsc_t * dsc = lv_event_get_param(e);
    /*If the cells are drawn...*/
    if(dsc->part == LV_PART_ITEMS) {
        uint32_t row = dsc->id /  lv_table_get_col_cnt(obj);
        dsc->rect_dsc->bg_color = lv_color_hex(MAIN_BG_COLOUR);
        if(row == 0) {
            dsc->label_dsc->font = &lv_font_montserrat_24;
@bader / @kisvegabor any help you can give would be greatly appreciated.
Thanks in advance!
I can recommend only a little bit hack solution.
  1. Set a larger top padding on the table
  2. For the header create a new table inside the normal table
  3. Set the position of the header to y= - 20 or so
